    I've been building an over engineered fog-light harness trying to make it as OEM as possible. Today I pulled the engine bay fuse box to try to use the empty spot in-between the btn and cooling fan fuse.
    The power wire is already ran to it so it only needs a terminal connecting to the spade that's already there. Unfortunately it was much larger than any of the spade terminals I had. So I buttend everything up and took a 40min drive to home-depot because it was rush hour and I will have a lot of time to kill tomorrow with my car so I wanted to be able to finish this part.
    Their largest spade terminal was smaller than the one I had.
    Going to have to hit up the junkyard and snatch one from a miata harness.
    Doing things the right way sucks.
    Beater=/= Sleeper
      shame your not closer i have a box of old harness parts. & even more in the garage
        By golly, the homebrew manifold and BW turbo are *bolted to the cylinder head* and feedlines are hopefully getting coneected today, on the driveway blocker car. Maybe someday it'll be a movable object.
          where are the pictures jay???
            Originally posted by Kitty View Post
            "laughably hard compared to any tire we'd contemplate getting on track with"
            Exactly as I described them, directly from the article. They're not "bad" tires, but I simply didn't like the way they drove.
            Team Fail Motorsports
            That's just the nature of the beach.
              Aw, one o these days I'l have time to poast pix...
                I replaced the door clips on the driver side with the ones from the Mazda3.
                It got rid of 90% of the door rattle. They're a much beefier design so I'll probably replace all the door clips eventually.
                Also
                to
                thanks to Ryan.
                Also got a fusebox spade from a miata, it's like 30cm for a 12-14 gauge wire, it's odd. Now I only have to do wire lengths for two relay to chassis wires and I'll be done with the fog-light harness. Looking for the fogs I'm fond of and the price of them has gone up quite a bit. Thanks Obama.
                Beater=/= Sleeper
                  interesting find on the mazda 3 clips! how much are they per pack/piece?
                    They were free at the junkyard. I just got a doors worth to see if they would fit proper.
                    Today was an old car day.
                    This afternoon after work I went out to find the steering wheel creaking like an old door. I should of greased the hell out of everything when I was putting on the miata wheel as I wipped everything down really well due to trimming metal/plastic. The turn canceler/spring was the culprit of this event.
                    After taking the car for a spin to make sure I got the wheel on perfect I was stuck in traffic and my car overheated. Well it only got to the 3/4 temp mark before it started billowing out smoke. Being Hawaii everyone gets out of your way when your car is smoking and as soon as I started moving the car went right back to it's happy place of 2/5 on the gauge.
                    The coolant temp switch plug had separated from the wiring. I've had not good luck with that entire assembly.
                    I also managed to blow the plastic plug on the where the second temp sensor goes on the ATX radiator. I didn't even notice this at first until refilling the radiator and noticed it was leaking. I suppose that was the weakest link in my current cooling system. I think if I can find another plastic plug I'll buy it because I'd rather that blow than one of the lines hidden under the intake manifold or the lower radiator hose. Also for reference it's a M14 thread pitch. I spent like $10 on big ass bolts today to figure that out.
                    I need to cut the bolt I purchased down about half an inch or so because it's too long to sit flush in the rad as it is now. It did hold some pressure in it's currently half assed installation though. I need to clean up some more plastic out of the threads as well.
                    Doing a compression test sometime this week just to make sure the engine is happy. Car seems to run just fine save for low revvving but that's due to moisture in the disty cap. Mad worse by me hosing the bay down.
                    Also I lost my second or third reservoir cap in all the failures. I had just gotten that one too.
                    Beater=/= Sleeper
                      ****ty fan switch design has always been ****ty :/ glad you didn't cause any further damage
                        Here was the visible damage. Unfortuantly i wasn't able to unscrew the remaining plasitc so I had to cut most of it out. Did a decent job to not **** the debris into the radiator
                        I'm going to need to trim this a good bit.
                        Don't mind the coolant, I had just popped the rad cover to see if it the system was holding pressure. Clearly it was.
                        I've got an alligator clip as the current stopgap for the rad fan switch. I'm debating soldering the wire to the connector and then filling the thing in with epoxy/resin.
                        Beater=/= Sleeper
                          [/URL]
                          Where's the turbo?
                          ._________________________
                            vj and accessories are sitting in the trunk of the 240 in storage.
                            I wasn't going to ship a leaky 16 year old turbo car to be my only car on an island where I wouldn't have time or tools to fix things.
                            Beater=/= Sleeper
                              swapped over to snow tires temporarily. stock wheels and coils are an awful combination, some ****ing peasant ****.
                              ended up ignoring everyone's tire recommendations entirely because the inside shoulder on each front tire was down to the wear bars so these are now drift spares for the 240 and I needed four (cheap) tires. whoops.
                              92 240SX: KA/T25, nerd mobile
                                kitty you need an aluminum radiator.
                                /rant
