    92 240SX: KA/T25, nerd mobile
      Originally posted by atomicEGT View Post
      does the RB20 have the same over-oiling and heat retention issues as the 25/6?
      No idea on that.
      Found the car:
      Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
      FS Forged H beam rods
      awaiting test fit
      Aluminum CAS/Distributor caps
      BP oil jet eliminators
      EV14 fuel rail spacers
      More stuff coming soon.......
        ooh, that makes a good noise.
          Random fitment photos.
          I'm going to have to make a really weird actuator bracket so it doesn't block the blocks water/oil ports. It doesn't contact the water return under the exhaust manifold though, which was a concern.
          Here is my factory fresh looking ac mount bracket. It still isn't cut down enough here. It needs a bit more cut off the top most portion. I was tired of dealing with it and just rattle canned it black until I do an IC fitment mockup.
          And a closer photo of the clutch line/motor mount clearance.
          It's going to be a bit of a rats nest in this area.
          Beater=/= Sleeper
            Damn, that's close...
            Mazda
            1988 Black 323 GT
            DOHC 16 VALVE TURBO
              run oil cooled only and solve half your problems?
                I'll just put marine grease in the bearing oil passage and seal it up while I'm at it.
                Beater=/= Sleeper
                  I'm running my T25 oil-cooled only, it gives no ****s.
                    coolant connections really only make a difference if you shut it down hot... as long as you "turbo time" it when you come to a stop, oil only is fine...
                      With the minimal amount of oil traveling through a BB turbo I wouldn't feel comfortable running it oil only.
                      Beater=/= Sleeper
                        Yours is BB?
                          BB is less sensitive to oil issues than a journal bearing anyway so if you cant run the coolant due to space issues it wont be a deal breaker.
                          awaiting test fit
                            Yeah,466541 Center section. I wish I could of picked up the one with the inconel wheel, but the premium for that was too much for the minimal benefit.
                            It's 2015 if you're not going BB you're poor, but that's just my opinion.
                            Beater=/= Sleeper
                              Depends on what you mean by less sensitive, they're a hell of a lot easier to over oil and force oil out of the seals. But it's less likely to blow out seals if oiled proper compared to journal bearings.
                              With a .04 restrictor I don't think enough oil would pass through it for optimal cooling, I know water cooling is mostly for oil coking prevention but with how big the water passage is on this turbo I'm sure it's beyond an optional function.
                              Beater=/= Sleeper
                                If I actually spent the money for a BB turbo I'd have to actually care about it, stock SR T25s are $100 so who cares? I don't worry about cooling, over-oiling, compressor flutter, etc
