    Originally posted by atomicEGT View Post
    replaced the front brakes today- Hawk HPS pads and some decent blanks. went to push the piston back in on one caliper and blew out the seal, so that was awesome. ended up replacing the calipers, too. pedal feel still sucks, new booster and adjusting the pedal will happen tomorrow.
    Interested to here the results of replacing the booster and the pedal adjustment.
    FS Forged H beam rods
    awaiting test fit
    Aluminum CAS/Distributor caps
    BP oil jet eliminators
    EV14 fuel rail spacers
    More stuff coming soon.......
      got too lazy to replace the booster, but between adjusting the pedal and the pads bedding in, the pedal and feel are right where I want them.
      also replaced a couple of haggard vacuum lines on the firewall in hopes of curing a possible vacuum leak/lean condition. car seems to run better, at least.
      92 240SX: KA/T25, nerd mobile
        got my front wheel bearings in the mail today.... looks like i'll be making more progress on the 323
          I just rotated off my old HP+ to StopTechs not to long ago. Somehow the dusting is worse, although I'm currently braking from higher speeds than my time in Hawaii. But I'm much happier with mid-heavy braking on colder brakes. I guess they stopped making those for a reason.
          Beater=/= Sleeper
            WE POLAND VENTS NOW.
            My attempt at getting the back-light dimming working proper on the Miata foglight switch failed. Better luck next time.
            Beater=/= Sleeper
              Installed the drivers side of this today to finish the pair.
              Put about 25miles on the car post install. Car is noisier over a speed bump I've gone over two times a day for the past few months and 60mph+ braking feel has a bit more confidence behind it.
              It's also cured my alcoholism and lack of faith in humanity.
              On a serious note I'll post a few install hints and my overall opinion on them after a weekend of beating on it.
              Beater=/= Sleeper
                Cures alcoholism huh. Where do I get a set?
                  :booze:
                  debating to install ARP wheel studs into my new front spindles
                    Doin 'something' right now...Click image for larger version
                      what ****ing goddamn assclown decided making an engine with NO TIMING MARKS WHATSOEVER was a good idea?
                      new timing belt, tensioner, fancy-ass Gold Coast idler pulley, and serpentine belt are in and the car runs exactly how it did before I took it apart, so: nailed it.
                        Are building an MZR(or similar) or just missing the plastic for the BP?
                          neither, Zetec.
                          besides, the BP at least has TDC marks for the crank and cams. the Zetec has slots in the cams for a lock tool for cam TDC (which doesn't do a lot for the dickhead VCT setup) and nothing for the crank, you basically just aim it slightly to the right of 12 o'clock and hope for the best.
                            Mocked up the MX3 center console... Need to track down the threads where someone else did this, as everytime I've looked at it.. I just scratch my head and wonder wtf is suppose to be removed...
                              installed fresh wheelbearings into my astina front spindles- still debating if i want to install longer wheel studs or leave the OE ones in place
                                I never liked the forward most part of the mx3 console. Protege front/mx3 rear is the best of both worlds.
                                Beater=/= Sleeper
