    Swapped in an A code and enjoyed a consistent idle and no cut out ripping through gears at WOT.
      installed fresh wheelbearings into my astina front spindles- still debating if i want to install longer wheel studs or leave the OE ones in place
      Are you thinking you might need to use wheel spacers???It won't hurt to use longer studs.
        i wasn't sure if i would need spacers in the back- the front i don't foresee ever needing spacers tho
          Installed the glass sunroof (ty bombdoutscort) and sold the BG to my brother. Noticed oil caked all over the passenger control arm and side of the block on the pulley side. Looked through the FSM and realized at some point in its bastardized state the crank pulley boss was lost. When the crank bolt was torqued more than likely it crushed the oil pump seal without the extra width of the boss. Local dealership wants $200+. Some dealer in Arlington is asking $90 shipped.
            Gave her a wash.
ID:	1241560Click image for larger version
            DX BP swap/turbo build
              man. that is realllllllllllly good.
              92 240SX: KA/T25, nerd mobile
                Originally posted by atomicEGT View Post
                neither, Zetec.
                besides, the BP at least has TDC marks for the crank and cams. the Zetec has slots in the cams for a lock tool for cam TDC (which doesn't do a lot for the dickhead VCT setup) and nothing for the crank, you basically just aim it slightly to the right of 12 o'clock and hope for the best.
                The crank actually does have something. There is a bolt on the radiator side of the block near the transmission and oil pan that you remove and insert a pin. It's a little hard to feel even with the proper tool kit and you have to remove the cat/down pipe to access it. The MZR is identical except it uses a different length pin.
                FS Forged H beam rods
                awaiting test fit
                Aluminum CAS/Distributor caps
                BP oil jet eliminators
                EV14 fuel rail spacers
                More stuff coming soon.......
                  that doesn't work on a ZX2.
                    ?? I just did a timing belt on an 01 ZX2. I bought an aftermarket tool kit that covers both engines. Zetec and Duratec.
                    awaiting test fit
                      yeah, it works on every other Zetec except for the ZX2, can't remember why. puts it like 180 out or something.
                        In avoiding a collision the other day I managed to miss-shift and over rev the engine quite substantially.
                        I was happy to drive away with only a mild knock instead of a hole in the block.
                        It sounds like the number 3 bearing is kill but I've never been very good at determining things from sound location.
                        I'm going to be a dirtbag and just replace the bearing(s) and hope it last till winter break.
                        I'd rather do that and ruin a set of $50 bearings than have the block self machining for three months.
                        Also dug my old block out of wood work and it appears to have a misaligned crank. Fun times.
                        Beater=/= Sleeper
                          gave it an interior bath/vacuumed the carpet. changed the oil & took it to chicago for a meet over the weekend.
                            Originally posted by 92dx View Post
                            Gave her a wash.
                            [ATTACH=CONFIG]66484[/ATTACH][ATTACH=CONFIG]66485[/ATTACH]
                            This looks like therieldeal's escort alot.
                            Tyler has spoken
                              I reached through the window to turn it on and got stuck in the seatbelt. Ouch.
                              Sent from my m8wl using Tapatalk
                              ClubProtege
                                Damn seat belts!
                                Sportsman's Guide (hunting, fishing, mil surplus etc) right now have brand new US govt surplus seat belts for $10/pair! 3 point retractables.
                                Sportsmansguide.com
                                The stalk side is little long (12") but I figure I can deal with that OK.
                                Belts are 112" long total, grey or black.
                                I bought 5 pr last night, get rid of all the stranglers in my cars.
                                Some of them are pretty nasty from wear, and some of them are blocked in place.
                                The rest of them keep trying to kill me.
                                FRM
