    Wow based on what they show online it looks pretty powerful!
    Where did you get your bluetooth obdII thing? This might help me solve the funky idle on my 99 wagon.
      eBay.
      http://www.ebay.com/ulk/itm/290674342587 (no idea if this link will work properly, my phone is being an asshole)
      92 240SX: KA/T25, nerd mobile
        Ordered, thanks
          no problem. I don't think that's the same seller I used, but it's the same adapter.
          not BG-related, specifically, but I used FORscan on my sister's Fiesta last night to figure out why the CEL was on. turns out when she had the PCM replaced under warranty they never bothered to clear the codes (PCM malfunction, TCM input malfunction, some **** with the ABS related to the TCM, etc). really impressed with all of the **** FORscan can do, like running the onboard diagnostic tests and reading live data from legit EVERYTHING.
            I drove it on very well plowed NC roads this weekend
            I can feel the rust multiplying just looking at it.
            Going to give it quite the cleaning once the roads stop getting covered in brine.
            Beater=/= Sleeper
              I know what you mean. I have to drive my rust free 323 this winter. I feel like I'm hurting it
              Sent from my SPH-L720 using Tapatalk
                trying to use epoxy to glue the support structure of my hood back to the outer skin didn't work, so I heat-taped a nickel to the intake pipe where the hood was starting to rub through because I can't be bothered to actually care
                  warmed it up. didn't dare drive it tho
                    Last week Friday (Jan 15):
                    Tossed a battery in my 323, fired'er up, drove it to work, came home, parked it in a different spot, so I could have an open spot for the AE86 coupe I bought later that night. Dug through the Gray 4WD protege looking for some parts I had stashed.
                      Post AE86 details in this thread please:
                        I stayed off the roads today.... because it's raining.
                        Sent from my m8wl using Tapatalk
                        ClubProtege
                          Thought I would share an update on my BG (ZX2). Note this is on my junkyard KLG4 engine that will eventually be cleaned up and rebuilt. This is only test fitting some items on a stand, I will do some trimming and fitting in coming months to mount it onto my KLZE/KLDE engine that is currently in my car. Enjoy!
ID:	1241766Click image for larger version
                            will that clear the brake booster/etc? looks pretty neat
                              The intercooler will actually come out a little more, towards the fender apron, about another 3 inches. It fits perfectly with the MX3 booster and master cylinder config I have in the car (because those are 3 or 4 inches smaller length-wise then the Escort). I test fitted the intercooler to my car before I ordered it (wrote down the dimensions and cut out the shape on paper). It just clears the master cylinder, clears the fender apron, and clears the wiper motor when it came it. Obviously I will have to use 90 degree brass fittings for the water, still need to order the pump, reservoir tank (pending location to put it), and heat exchanger.
                                can't wait to see everything in the engine bay
