Included in the sale will be the Engine, transmission, clutch, flywheel, shifter assembly and cables, intercooler, radiator. This is basically everything I pulled out of my GTX when I did the BPT swap. Here is a link to everything when it was in the car http://www.wihandyman.com/forum/show...-SE-PA-323-GTX .
The engine is a B6T with GTX head and cams, B6T block, Miata auto pistons, GTX rods, Miata big nose crank. Motor runs well but smokes heavily. Compression is 1-100psi, 2-180psi, 3-175psi, 4-220psi (54*F). **Turbo and manifold have been sold**HKS SSQ bov. The intercooler and radiator are both custom and the radiator has to be run with the setup or the thermostat housing and waterpump will have to be changed. Tubing was welded to both of these. The injectors are stock GTX. The previous owner said the clutch was slipping but I didnt have any slippage even at 12psi. But I also wasnt running the car hard. So I wouldnt expect much from the clutch. The chassis has around 122,000 on it so I am assuming the transmission has the same amount. Trans shifts great, no noises, transfer case output flange has no play, electric diff lock did not work, but I could manually lock the diff, bronze shifter bushings included but not installed, trans and transfer case fluid level and condition where checked when I got the car and both were good. I am running an AEM EMS so I do not have a distributor, air flow meter or ECU for the engine. However I do have parts from the BPT that I am not using such as the dizzy, and ECU if they are of any help. I do not want to part anything out right now so I am only looking to sell everything as a package. Just let me know if you have any questions. $500
