Results 1 to 5 of 5
Thread: ODB-II Code P0421
  1. #1
    Registered User
    Join Date
    Jul 2010
    Location
    NY
    Posts
    8
    Feedback Score
    0
    ODB-II Code P0421
    I was wondering if anyone had any experience with the check engine light code P0421. I believe its either a bad catalytic converter or a bad downstream Oxygen Sensor.
    2001 Mazda Protege LX 2.0L 182,000mi
  2. #2
    Registered User
    Join Date
    Oct 2006
    Location
    Glendale hts, IL
    Posts
    825
    Feedback Score
    3 (100%)
    po420 is cat efficiancy below threshold.. 421 is also a cat code for bank 1 i believe in the case that you have 2 cats.. 1 dog and a turtle..
    anyway.. how many miles on the car? any missfires? or been a long time since a tuneup?
    more then likely its the cat isnt working right 2nd option is the DS o2 sensor 3rd option is to just get a obd1 car.. emissions suck ass
  3. #3
    Registered User
    Join Date
    Feb 2012
    Location
    Virginia
    Posts
    3
    Feedback Score
    0
    Quote Originally Posted by thtdudenamdbill View Post
    Had the same problem. It was the Pre-Cat. It was completely burned out due to bad ignition coils previously. I changed the O2 sensors prior to the Pre-cat hoping to save some money but to no avail. It was the Cat the whole time.
  4. #4
    Registered User
    Join Date
    Jun 2011
    Location
    Texas
    Posts
    29
    Feedback Score
    0
    If you have had any ignition problem recently( timing belt/misfire/bad coils)then your pre-cat will need to be replaced. There are many ways to work around this problem. Install header, and or use the non-fouler trick. Be aware that these tricks may not be acceptable with your emissions inspection. BTW I also have the 2001 LX 2.0 with 180000 miles and I just replaced the pre-cat. I believe my cat failed because a mechanic installed my new timing belt a tooth off causing the ignition problem. Anyhow not that hard to replace if you do any simple mechanic work. Check out the thread: Tips for replacing pre-cat
    Hope this helps, let us know how it goes.
  5. #5
    Registered User
    Join Date
    Jun 2011
    Location
    Texas
    Posts
    29
    Feedback Score
    0
    Oh, If your getting the P0421 code then I would say that the O2 sensor is doing exactly what it should be, reporting. That
    pretty much says that it is working. I believe this is the most common mistake made. "My O2 sensor is reporting. Well it must need replacing". WRONG!
    Also if you haven't resolved the ignition problem. Then don't expect your new cat to last very long.
Thread Information
Users Browsing this Thread
Similar Threads
  1. k code help
    By wa-sleeper in forum Engine/Drivetrain - BG Chassis
    Last Post: 01-08-2011, 02:37 AM
  2. R code VAF and B code VAF what is the difference
    By rustybarnard440 in forum Engine Management & Proper Tuning
    Last Post: 10-18-2009, 12:40 PM
  3. CEL P0421 Help - '99 LX
    By TomBodet in forum General Discussion - BJ Chassis
    Last Post: 08-16-2008, 10:33 PM
  4. code 09
    By gd71 in forum Engine/Drivetrain - BG Chassis
    Last Post: 06-28-2007, 10:39 PM
  5. ODB-II For Trade/Sale
    By 92protuner in forum Parts and Misc. Items For Sale Only
    Last Post: 01-06-2005, 11:11 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
