torque for header bolts
    Does anyone know the torque for the bolts on the header of a 00 1.6
    Mazda Protege 2000 LX
    According to the FSM, the torque setting for the 2.0 L exhaust manifold to head mounting nuts is 15.7-22.5 Nm (11.6-16.5 ft/lbs). Should be similar for the 1.6 L engine.
      Thanks!
        You're welcome.
          The header is installed now! I will post a picture our video soon hopefully
