JR-COZY 1990 FORD Laser TX3 from New Zealand. 315KW @ 29psi!
    Cant copy paste my build thread due to the 25 pic post rule,
    This is my NZ original build thread. many many pages
    This is my latest FEOA build thread, tried to copy paste it but too many pics.
    Hi All, I'm Carl from New Zealand and this is my project Ford Laser TX3, the same shell as your US 2nd gen escort. Jim Pierce motorsport supplied the carbon parts!
    Anyway after a 4 year build my car is tuned and nearly road legal.
    Heres the Project thread!
    My new car is a 1990 tx3 that i got because it has a steel 6 point cage in it. saved me time and money to buy this.
    1990 Ford Laser TX3
    JR-COZY
    Best Ford, Best undercarriage at 4&Rota Nationals 2012
    Best Ford, Best undercarriage, Best Displayed vehicle at Wings vs Wheels 2012
    315kw at the wheels, Sponsored by:
    MRP LTD - Manon Racing Products
    1990 Ford Laser TX3
    JR-COZY
      for steve
      1990 Ford Laser TX3
      JR-COZY
        SUPERLAP MODE,
        shes got oil and a handfull of little bits till start up.
        Finally sorted triggering, JRCOZY now up and running,Thanks to Mike Cullingford and Chris Burrett for the help.
        10-12-11, Ground Level Carpark show, took out best paint after entering half way through the show.
        Launch control
        Finally got my old skool gizzmo launch controller to work.SM4 sequential ignition and COP with built in ignitors, who needs the new 6 ouput version :D
        1990 Ford Laser TX3
        JR-COZY
          Making 10psi (wastegate pressure) with launch control.Old style Gizzmo launch control made to work with 4 coil COP sequential ign.
          Done 700ks now. Nearly time to dyno tune!
          New rims were fitted today, transformed the look of the car.
          Catch it at 4&Rotary Nationals Show next Saturday along with
          [AL4SPN] (My old plate) Nobodys BFMR GTAE
          and
          [0 GRIP] MRP toyota Leving GTZ
          Thanks to OSIRIS developments and 4&Rotary 2012
          JRCOZY made it onto speedhunters!
          Speedhunters is an international collective of photographers, writers & drivers with a shared passion for uncovering the world's most exciting car culture stories.
          258KW at 20psi
          315KW at 29psi
          Thanks E&H motors!
          thanks guys!
          dyno vids
          1990 Ford Laser TX3
          JR-COZY
            1990 Ford Laser TX3
            JR-COZY
              1990 Ford Laser TX3
              JR-COZY
                definitely one of my favorite builds on amazd. welcome!
                NW MAZDAS
                  damn that is cleaaaaan!
                  I love everything about it btw, does the variable valve timing work?
                    Wow man what a nice build this was. You covered that car at all angles.
                      Very impressive.
                        super sweet. awesome job
                          Thank you!
                          VVT sure does work.
                          Post from my tuning shop, E&H motors, tuner is also named Carl.
                          Variable valve timing (VVT) tuning. Each line represents a different relationship of valve timing to crankshaft position. Carl does this to get a baseline of where the VVT wants to be, and then takes the best points of the results and incorporates that into the VVT map. We can have a car that is super responsive and makes boost quickly, but will not lose massive amounts of power up top because of too much overlap. E.g. the green and red lines have high amounts of VVT advance (intake), which causes then to spool up quickly but reduces the amount of top end power. This doesn't only apply to full throttle runs though! Valve advance and overlap can be reduced when cruising for better fuel economy too!
                          1990 Ford Laser TX3
                          JR-COZY
                            beautiful. I REALLY like your slimmed-down engine support, that is very nicely done!
                            --sarge
                              amazing! I think you're sporting my favorite BP setup yet. ITBs, VVTi, and boost. What could be better? Well, other than traction haha.
