Looks like the SOHC 1.8L, B8 (I think). The BP is a DOHC engine. As far as I know, the heads can be easily swapped. Other than that, I don't know what you can do with the SOHC.
The Sohc and Dohc are both considered to be bps. Most consider the Dohc to be the bp and the Sohc as a b8
Sorry I should've been more specific. The Sohc is called the bp01 and the Dohc is the bp05.
For the head swap I believe you need the head, water pump, intake and exhaust manifolds. Of course plug wires. Now when you do the head swap you will have lower compression than a normal bp05. That's why people are telling you to boost it.
Me personally is just go find a bp05. And drop it in. The wiring can be nodded. The correct ecu you'd need is bp09 or bp10. Either one will work. Is that a fwd or 4wd?
Man I ave been searching all day for this engine.. I will have to put that upgrade on hold (sucks to be in ja) but more mods will be done! will post done mods!
