Kia transmission confusion
    It'll be a mostly stock KL with high compression pistons. Nothing crazy.
      Originally posted by zoom-zoom View Post
      Has anyone here tried to swap the bell housings?
      yes
      I know they're probably "close" but close =/= same.. by the time your average first timer swaps the clutch housings, they have countless hours, headaches, one time use tools, and days worth of part searching for the right spacers and hopefully new bearings and seals they replace.
      unless youve tried it no, you dont know, so please dont assume.
      The EGT g series and capri xr2 g series are always referred to as the same, but they are not, I spent weeks trying to get my xr2 transmission together after I put an mfactory differential in it because they are NOT the same like everyone says. Best bet is to just buy the transmission you need for your motor, you will spend as much or more rebuilding and getting the custom machine work done, and with a jy tranny, usually you get a short warranty incase it doesn't work.
      There are also differences in the way the engine is clocked, or the way the differential is clocked, however you want to look at it, between g series transmissions.
      ford interchanges dont effect us mazda folk, sorry about your luck
        Your talking about swapping KIA and Mazda clutch housings and case/internals....if there are differences between the Mazda case, and the ford/mercury case, then KIA starts making a third version, you really think it will be identical in every way? If I were a betting man I would say the halves will swap, and the gearsets/primary secondary shafts/reverse gear/differential line up with the same holes. I'm just trying to let the op know that, from experience, I know even putting the same transmission back together 'right' requires new shims, then seals and bearings if you want to go the extra mile, and good luck sourcing the parts without paying a dealership. There's more to 'just swapping' housings, even the mounts will probably be different.
        1993 Ford Festiva - Fiona/b6 swap
        1997 Ford Aspire - Peaspire/rescued restored and sold
        1994 Ford Aspire - Kiazord/BPG5MR Swap
        1999 Mazda 626 - exDD, sold
        1997 Ford Aspire - Babyspire, stock low miles&clean
        1994 Ford Aspire - Crustyspire, scrapped
        2003 Chrysler T&C - grocery getter
          the kia case swaps over I said that in my last post, ive tried it on the bench it fits...
          putting any tranny together right requires the same so your point there is moot.
