Again, '95 ES should have a G-series. Everything rose was F-series. The '94-'97 Kia Sephia with the 1.8L (BP) used a Mazda G-series and it's a little bit beefier. If you go with the Kia transmission, you'll also need the axles since the diff has 28 splines instead of 26 splines for the Mazda transmissions.
kertap's daily driver
They are pretty clouded, but still looks repairable. There's a kit made by 3M that includes 500 and 800 grit sanding discs, 3000 grit wet-sanding disc and a buffing disc with rubbing compound. My original headlights looked like yours, but after using the 3M Headlights Restoration kit, they looked brand new.
Edit: This is what you're looking for:
You can find it at Walmart, Autozone, Pep Boys, etc. for around $20.
And here's a video of how it works and what to do:
http://www.youtube.com/watch?v=_t1RBw0IGXA&feature=youtube_gdata_playerLast edited by irishkev90; 06-14-2012, 10:01 PM.
