Hey guys, Great stuff in those stickys! I'm trying to get some wiring stuff figured out for my car. It's different, and it's my first swap, so please bear with me, any comments/suggestions are appreciated, at this point I'd even settle for some spam posts in my threads, nobody seems to want to help, or can't.
Anyway, the car is a 94 Aspire, the Engine is a 93 protege LX, the Engine harness is from a 91 LX, and the ECU is a stratified PnP 90-94 ms2.
I stripped all the old engine electronics and A/C component wires from my cars wiring harnesses. I'm looking at a mess right now, but I think it's gonna work. The Start/charge/main fuse box/dash fuse box/headlights... are all on my aspires wiring harness, and I'm trying to use the BP harness with the ECU, there's only a couple wires that need spliced to make this work, and I'm trying to figure out which ones those are.
First question, what is the deal with the fuel pump? I have to jumper power to it, ok, does it run constant (run/start) or does the ECU tell it when to kick on?
I have a thick blue wire from the BP harness, I think it's the main power to the engines electronics, and I've got a long tail from the old disty power (same thick blue wire) I'm about to splice together. I've figured out alot of the BP harness, but I'm hoping you guys can help me identify some wires. 30lbs of books and 6 fsm's and I'm still looking for a decent wiring diagram.. let me get some pics, sec.
