Results 1 to 12 of 12
Thread: Shifter fell through.
  1. #1
    Registered User Mr.Sarb's Avatar
    Join Date
    Oct 2011
    Location
    Macon, GA
    Posts
    7
    Feedback Score
    0
    Angry Shifter fell through.
    The issues with this car just never seem to stop. My '93 Protege LX just dropped a big ole fun one into my lap. While I was backing out of a parking spot the shifter dropped down. It appears that there was a hard rubber isolater that attached the shift Lever and the control rod to the extension rod, and it has decided to say, "**** you I'm out!" The only thing keeping the shift linage and everything from grinding into the pavement is the exhaust. Where can I find a replacement for this, or should I just have the damn thing welded together and say **** it? If need be I'll take some pictures to clarify.
    "The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
    -John Stewart Mill
  2. #2
    Raping the knowledge
    Join Date
    Jun 2007
    Location
    st catharines ontario canada
    Posts
    3,327
    Feedback Score
    19 (100%)
    no need for pics .. as a short term fix take 2-1.5" self tapping screws and run them through the tabs ( if you look down at the shifter you will see 2 " bumps" one either side of the assembly) this is where the rubber was bonded to the metal frame of the assembly. be sure the rubber is all the way in and the screws will go through the metal into the rubber. i did this with mine several years ago and it is still holding up . an alternative is to make an anti-drop bracket which will require welding
  3. #3
    It happens Ksolomon84's Avatar
    Join Date
    Mar 2009
    Location
    Lackawanna, NY
    Posts
    29
    Feedback Score
    0
    I've done the same thing on 2 cars. Works good
    Its all fun and games until someone turbos an Escort
  4. #4
    16's on the Family Sedan 93BlkOnGreenPro's Avatar
    Join Date
    Jul 2007
    Location
    Greensboro, NC
    Posts
    2,809
    Feedback Score
    14 (100%)
    this is what I did.
    It looks like this from in the car:
    It looks like this from under the car
    What I used to make a bracket; a old bumper mount.
    How I made the bracket.
    Finished product using lock nuts. This is solid solution if you don't have access to a welder.
    Install Shifter Bushings: http://www.clubprotege.com/forum/sho...491#post646491
    Custom HID's: http://www.clubprotege.com/forum/sho...&highlight=hid
  5. #5
    Registered User
    Join Date
    Jun 2013
    Location
    AZ
    Posts
    6
    Feedback Score
    0
    Zombie thread bump! This just happened to my 92 LX. Kudos on the DIY repair but is there a replacement part to fix this problem?
  6. #6
    Join Date
    Aug 2003
    Location
    Madison, Wisconsin
    Posts
    24,000
    Feedback Score
    79 (100%)
    pull it back into place & fill around the rubber with polyurethane caulk in a tube from any of your local or mainstream hardware stores. easiest solution.
  7. #7
    Registered User
    Join Date
    Jun 2013
    Location
    AZ
    Posts
    6
    Feedback Score
    0
    Quote Originally Posted by FE3-323 View Post
    Appreciate the quick reply FE3-323. I understand that may be the easiest solution but is it a good lasting solution or will I have to revisit this in a few months/years? Heat is big concern living in AZ..
  8. #8
    Join Date
    Aug 2003
    Location
    Madison, Wisconsin
    Posts
    24,000
    Feedback Score
    79 (100%)
    Shouldn't be an issue, polyurethane is pretty tuff stuff. Its still holding in my 323. And thats been 6 plus years.
  9. #9
    Go ask Alice me109's Avatar
    Join Date
    Nov 2004
    Location
    Just outside Beer City USA
    Posts
    2,859
    Feedback Score
    10 (100%)
    That's got to be a strange feeling. Never happened to me. Can't quite imagine what it would be like.
    1990 Protege 4WD
  10. #10
    Registered User
    Join Date
    Jun 2013
    Location
    AZ
    Posts
    6
    Feedback Score
    0
    Six years eh? Imma give that serious consideration dude. Now to figure out how take apart the shift boot and console..my google-fu has become weak from lack of use
  11. #11
    zoom zoom irishkev90's Avatar
    Join Date
    Aug 2009
    Location
    Queensbury, New York
    Posts
    3,143
    Feedback Score
    0
    Closest thing I could find with a quick Google search. It's not a tear-down tutorial, but it shows all the pieces and fasteners to give you an idea. If it's anything like a BH, it should be pretty simple to remove. I would also take the opportunity to clean up under the consoles while you have them out of the way.
  12. #12
    Join Date
    Aug 2003
    Location
    Madison, Wisconsin
    Posts
    24,000
    Feedback Score
    79 (100%)
    the shift knob & aprox~ 4 screws
Thread Information
Users Browsing this Thread
Similar Threads
  1. shifter fell through!
    By blooprint in forum Engine/Drivetrain - BG Chassis
    Last Post: 07-24-2006, 01:21 PM
  2. RearView Mirror fell Help!!!
    By RacerX in forum Exterior/Interior - BHA Chassis
    Last Post: 07-06-2005, 12:47 AM
  3. Crank pully fell off?
    By nekoashide in forum General Discussion - BG Chassis
    Last Post: 03-18-2005, 07:27 PM
  4. Clock Fell Back into Dash
    By arosborough in forum Exterior/Interior - BG Chassis
    Last Post: 02-21-2005, 06:51 PM
  5. My Lca Just Fell Off
    By ChrisKory in forum General Discussion - BG Chassis
    Last Post: 09-02-2004, 10:29 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
