B6T/BP Valvespring Compressor
    Just finished making this up, got to do the valvestem seals in the GTXR2 & I don't want to remove the head, so that rules out the C-clamp style. Didn't want to bother with the bracket/lever style either as it doesn't lock into place.
    It works pretty darn good!
    Creator of the B6T Rocketchip
    www.werbatfik.com
    so simple, yet so awesome! Amazing design as always sir! What would a CP member pay for a Rocketman B series valve spring compressor
      lovin it. that would be a huge time saver
      NW MAZDAS
        awesome design!
          Is that a one of a kind device or you'll be putting it into mass production?
            build more!!!
              I'd buy one if you make them to sell
