tired of chasing my problem
    just picked up a 00 with 171k on it. it's the 1.6 auto. it's throwing a cel of p0106. map sensor or large vacuum leak. replaced the map and put new vacuum line on it. the accordian part of the intake was shot so i cut it out and put a piece of conduit and hose clamps to seal it. it's still throwing the code. then chased all vacuum lines with ether. if there's a cracked line, the engine speed will jump up. nothing happened. so what could be wrong?
    The ether check isn't foolproof. Make a fitting that replaces the filter that lets you pressurise the intake tract. Look for the hiss.
      I thought I heard somewhere the intake manifold is a prone problem. Might want to grab a new one and check that out.
        P0106 Baro Circuit Performance Problem
        According to the FSM, possible causes are as follows:
        1. EGR boost sensor malfunction or substandard performance
        2. EGR boost sensor solenoid malfunction
        3. Loose, damaged, misconnected, clogged or frozen moisture in vacuum hose from EGR boost sensor solenoid to EGR boost sensor
        4. Loose, damaged, misconnected, clogged or frozenmoisture in vacuum hose from EGR boost sensor solenoid to EGR valve
        5. PCM malfunction
          Yes, the intake manifold gasket can be a problem, but the car will throw a P0171 code.
