Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: TheDanny, My 1988 Mercury Tracer
  1. #1
    Registered User TheDanny's Avatar
    Join Date
    Dec 2010
    Location
    Hamilton Ontario Canada
    Posts
    166
    Feedback Score
    0
    I have posted here before but never started a work log. Quick run down of what I had, what I've done and what I plan on doing.
    I purchased a 1988 Mercury Tracer two years ago. B.C. car, very minimal rust (no holes) and besides your basic maintainance she only needed one thing. A heater core . Well why not replace the dash with a 323LX dash (entire parts car was only $200) and cluster while I had this one out, so I did. Last winter I aquird a 1989 323 GT parts car, and removed the motor and drive train for a direct swap into my car. The GT also came with a full GTX interior. Everything from the GT was installed before last May when I put the car back on the road.
    Its also been quite a while since I have worked on my car besides basic maintainance. So this winter while my car is hibernating (away from the salt and snow), I plan on the following list to be completed by May.
    -Turbo: Hybrid VJ14 hot/ VJ11Cold side, more aggressing veins on the turbine and I believe Cherry Turbos said 80% waist gate dump.
    -2.5" Turbo back exhaust with custom CAT/Resonator/Muffler
    -HKS piggy-back ECU
    -HKS Manual Boost Controller
    -After market intercooler and Custom Oil Cooler
    -Fidanza light weight flywheel
    -CM FX300 Clutch kit
    -MSD ignition and upgraded plugs
    Non Power mods
    -Finish my paint job (just needs a few more coats)
    -touch up some very very light body work
    -shorten bumpers
    -replace baffles in valve cover, as I have oil getting to my intake manifold (or install the catch can I made months ago and never got around to installing )
    Should be a good build.
    1988 Mercury Tracer. (aka Ford Laser)
    "If you do not try you cannot fail, but neither can you succeed.....however....If you dont have any clue what your doing, please, ask for help."
    The above quote does not in any way imply that I know everything, but rather that I too need to ask for help sometimes
  2. #2
    my name is a verb now Turpro's Avatar
    Join Date
    Jan 2004
    Location
    Cincinnati suburb Ohio
    Posts
    17,189
    Feedback Score
    73 (100%)
    Sub'n. Waiting for pics.
    Quote Originally Posted by jay View Post
  3. #3
    Raping the knowledge
    Join Date
    Jun 2007
    Location
    st catharines ontario canada
    Posts
    3,327
    Feedback Score
    19 (100%)
    waiting on some pics as well .. nice to see another local
  4. #4
    Join Date
    Dec 2010
    Location
    Posts
    166
    Feedback Score
    0
    Dec 2010: This is a photo that was sent to me from the previous owner. He didn't have any photos in his add
    There isn't much to look at. Stock Mercury Tracer interior, the cluster didn't have a tachometer. You can see the little black box in the passenger footwell. That was the owners attemping to MacGyver an R.V. heater into the car, rather then replacing the heater core
    May 2011: Prepping for bodywork and paint
    More Prep
    1 Gallon of Tremclad + 1 container of mineral spirits (varsol) + 4" Foam Rollers and 24 hours of labor not including drytime
    June 2011: H&R Sport Springs mounted on KYBgR2's
    Feb 2012: Almost ready for the swap, just have to give her some TLC. Thouched up any of the spots that may have had some corrosion and a good degreasing.
    All Clean
    Time to move it over.
    Installed
    June 2012: Final coat on the bumpers. They used to be unpainted worn and weathered grey
    Also painted and installed the front swaybar before I installed the front bumper
    New wheels and tires to finish her off for the season. Tires are 195/55/R15 Dunlop Direzza Star Spec's
    Oct 2012: I figured I would get a shot right after I cleaned her for the last time this season. I took her off the road three days later
  5. #5
    Join Date
    Jan 2004
    Location
    Posts
    17,189
    Feedback Score
    73 (100%)
    Looks good. I thought about doing the roller paint job. Came out good as far as I can see.
  6. #6
    Join Date
    Dec 2010
    Location
    Posts
    166
    Feedback Score
    0
    The only regret I have is that I didn't have enough time to do it as thorouly as I wanted to. It was a little too cold and much to damp when I started. I should have left the paint for three to four days between painting and wetsanding. It wasn't until about three months later that the paint actually hardened up (due to the extent you have to thin the paint to minimise orange peal). This is the second season with the same 6 or so coats. Hasn't had a final wet sand or pollish yet. Wasn't going to spend ten hours sanding her when I was planning on adding more.
  7. #7
    Join Date
    Dec 2010
    Location
    Posts
    166
    Feedback Score
    0
    If i wanted a rear disc brake conversion, what would I have to order? Im told a capri rear disc swap is common for BF's. Which model and year of Capri do I need? I want to keep my 114.3 bolt pattern and stock disks sizes for the 15" wheels.
    ...and Merry Christmas.
  8. #8
    Join Date
    Dec 2010
    Location
    Posts
    166
    Feedback Score
    0
    Cool July 2012ish
    Went under this bridge in St. Thomas on my way to drop my turbo off at Cherry Turbos. Had to stop for a photo on my way back
  9. #9
    Join Date
    Jun 2007
    Location
    Posts
    3,327
    Feedback Score
    19 (100%)
    Ive laughed @ the golf a few times seeing around town
    BF looks good
  10. #10
    Join Date
    Dec 2010
    Location
    Posts
    166
    Feedback Score
    0
    Thanks. I love and respect my car more than anything. The Harliquin isn't mine. Not my flavour of car if you know what I mean. I rent from his parents.
  11. #11
    Registered User
    Join Date
    Jun 2012
    Location
    ATL, Georgia
    Posts
    170
    Feedback Score
    0
    I see you wanna do the vj14/vj11 hybrid.... Just want to let I have a vj11 in good condition that has a cracked back housing for sale.
  12. #12
    Join Date
    Dec 2010
    Location
    Posts
    166
    Feedback Score
    0
    I took my vj14 to a company in St.Thomas Ont. He had a cold side from a vj11 already, fair price plus all the work to the waistgate and manifold porting. Thanks though. If im satisfied with this one, then I might PM you down the road when I start building my other B6T (if you still have it at that point of course).
  13. #13
    azgtx
    Join Date
    Nov 2006
    Location
    Mesa AZ
    Posts
    1,465
    Feedback Score
    30 (100%)
    Capri rear disc is direct bolt on swap...no need to change the proportioning valve either.
  14. #14
    Mazda Whore Ace's Avatar
    Join Date
    Dec 2008
    Location
    Vero Beach, FL
    Posts
    4,707
    Feedback Score
    14 (100%)
    Quote Originally Posted by TheDanny View Post
    Lookin good on the tracer! and those VW's are pretty rare apparently.
    -Steve
    94' Protege < Worklog<SOLD!
    VF10 powered!
    262 Whp & 257 Wtq
    13.1@107
    '02 Suzuki Bandit 600s
  15. #15
    Join Date
    Dec 2010
    Location
    Posts
    166
    Feedback Score
    0
    Direct swap means brand new parts, sweet! Cheers. Yes, rare but rubbish, well atleast in the condition this one is in.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Mercury Tracer LTS
    By 93BlkOnGreenPro in forum Parts and Misc. Items For Sale Only
    Last Post: 12-21-2011, 06:50 PM
  2. 1989 Mercury Tracer
    By porter_roc in forum Ford Escort
    Last Post: 09-22-2011, 08:32 PM
  3. 1995 BPT Mercury Tracer
    By bam in forum Protege's and Other Cars For Sale Only
    Last Post: 07-30-2011, 02:43 PM
  4. mercury tracer engine! in need!
    By Mellifebaby in forum Want To Buy/Trade Items
    Last Post: 11-22-2010, 12:43 AM
  5. 89 Mercury Tracer Hatchback
    By disposable in forum Internet Sightings
    Last Post: 09-11-2008, 06:24 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
