Welp, I've been putting this off long enough. I picked up a pro4wd off of deadly_sleeper back in august and drug it back home. Since then I have been acuiring as many parts as I can in hopes that I will have time and weather on my side in the spring to get it going. This is not a logical project by any means. I will be spending more money and more time on this car then I could ever dream of getting back out of it but in the end it should be as nice a early 90's japanese econobox as you can get. Besides it will still be far cheaper than buying an evo and modding that, so I consider my self ahead lol. Would like to give a special thanks to my wife for allowing me to be so dumb, not to mention often my parts migrate into the bedroom and other various parts of our home. Also, Bo gaut for taking much of my money in return for parts I am too lazy or uncapable of sourcing my self!
05/04/2013 - Um, so I picked up another pro4wd due to the damage of the red car. Good news is my wife says I can keep the red one too!! I have enough parts to build both, so I think I will.
Lets start with goals of the build:
Drivetrain:
GTR BPD long block
webcam 505 +2.5 cams
Corksport adjustable cam gears
gtr intake manifold
Dual feed billet fuel rail(May be some sort of early m-tuned)
Fuelab RRFPR
Denso 660cc fuel injectors (for now)
Gtr exhaust manifold
vj-23 turbo
externally gated stainless downpipe (turbosmart racegate 48mm)
lightweight flywheel
MTX-L wideband setup
Megasquirt (have ms2 considering ms3-pro)
alky injection
USDM protege 4wd tranny
Evo brass shifterr bushings
filled mounts
Ferdi 4wd crossmember bushings
GTR drive shaft(if its different from a regular one lol)
eventually GT4 conversion
Suspension and Brakes
Five lug conversion on all corners (involving all new spindle hardware, bearings and seals)
4-piston front brake conversion
kyb gr2 with ground control sleeves and H&R spings (till I get k-sports)
Poly bushings everywhere
new balljoints, inner and outer tierods (etc.)
probably replace axle grease and boots
Pierce motorsports strut bar(s)
Pending- FE3's traction bar
Cooling
Custom aluminum radiator to sit where a/c evaperatorr sits
new hoses and heater core
Interior
GTR front seats
clean and dye carpet
manual seat belt conversion (live close to canada)
black interior conversion
Headliner and door panel inserts to be rercovered in suede material to match gtr seats
Rear seats to be re-upholstered similar to front seats
TBD- clean gauge installation
wink mirror ( loved it in my egt)
N/A audio system (again loved it in my egt)
Exterior
Three-hole front bumperr with lip
yellow lens round fog-light grill
EDM Projector Grill
non-usdm corners
tyc front lights with Projector retrofit
rear familia garnish
series 2 rear bumper
New front frame horns and radiator support
foha side skirts
foha rear deck lip spoiler
wedsport tc105n 17x9 +25
mazda rainguards
tinted windows
lx body match handles and mirros
FULL body re-color (need some input; thinking white or silver)
Now the pictuers! car and parts so far:
following me home!
Drivetrain:
GTR BPD long block
gtr intake manifold
Fuelab RRFPR
vj-23 turbo
alky injection
filled mounts
Cooling
Interior
GTR front seats
Exterior
EDM Projector Grill
non-usdm corners
foha side skirts
mazda rainguards
tinted windows
following me home!
