Which head gasket?
    Which head gasket?
    So it's time to replace my head gasket and I wondered which one I should buy. ebay has them for cheap, but are those any good? Mazda wants $82.30 for theirs. Is it any better than the cheap ebay ones?
    What is your opinion?
    1990 Protege 4WD
    1 3 5
    2 4 R
    turbo?
    use OEM.
    92 240SX: KA/T25, nerd mobile
      Sounds reasonable.
      1990 Protege 4WD
      1 3 5
      2 4 R
        I ran 35+ psi with a Holset through one of those for a while without a problem (using ARP studs too).
        I mean, there's the possibility now that it finally let go, but that was with a TON of abuse. the OEM gaskets are the jam.
          Personally, I've used Eristic gaskets without any issues yet. I still haven't had to use their headgasket tho (knock on wood). I haven't had any major leaks from the gaskets I have installed (intake/exhaust/disti/cams/crank f&r)
          They actually come with the PROPER intake/exhaust gaskets too. The exhaust is MLS like OEM, and the intake is stamped aluminum like the OEM ones, not that stupid crush mesh type most people us on their exhaust systems.
          example of what you don't want your intake/exhaust gaskets to look like
            Good to know. Thanks for the link.
            1990 Protege 4WD
            1 3 5
            2 4 R
              np! I just realized that's for the BP4W head tho lol so if you do go with them make sure it's for the 94-98 lol
