2003 MSP KLDE Swap
    2003 MSP KLDE Swap
    Hey everyone, I'm in the middle of swapping a KLDE into my 03 MSP and have run into some problems with wiring. I knew it was going to be the hardest part but I really have no idea what I'm doing and can't seem to find too much on wiring specifics of this swap. The donor car for the swap was a 96 (if I remember correctly) Ford Probe GT so I was planning on using the harness out of that. I was told it would be plug and play, so to speak. I've pretty much detached all the wires on the old harness except for one inside that runs under and into the dash. I'm just wondering if anyone has experience with using a probe wiring harness in an MSP swap. Any advice/tips etc. would be greatly appreciated. Thanks!Click image for larger version
ID:	1269778Click image for larger version
ID:	1269777Click image for larger version
    Welcome to the club. I can try and help you out, although I think the obdii Probe harness is a bad idea. What specifically is the issue?
    1992 Familia GT-X
    1988 323 GTX
    2011 F150 Lariat Ecoboost
    2014 Civic Touring
      Thanks for the response. Sorry, I was mistaken before. It is an obd1 harness. I haven't run into many problems so far but just taking out my old harness I'm seeing plugs that aren't on the probe harness. The only one problem I have run into so far is that theres a wire on the original harness that runs under the dash. i wasn't sure if I should just cut it or try to get to it. I'll post a pic up here. Not sure if you'll be able to see it though.
        I left my original protege ecu in the car to control a few things.
        1992 Familia GT-X
        1988 323 GTX
        2014 Civic Touring
          So should I keep the protege harness in and just cut whatever I dont need out? I'm took some pictures I'll post them in a sec once they upload
ID:	1234731Click image for larger version
ID:	1234732Click image for larger version
ID:	1234733Click image for larger version
ID:	1234734Click image for larger version
ID:	1234735Click image for larger version
ID:	1234736Click image for larger version
ID:	1234737Click image for larger version
ID:	1234738Click image for larger version
              Well, that would be the easiest. Not the most elegant solution. I ran mine for a couple years that way trouble free. If I we're to do it again, which I might someday, I would use a KLG4 with the entire KLG4 electrical system. It is possible to make it emissions legal that way.
              1992 Familia GT-X
              1988 323 GTX
              2014 Civic Touring
                I've wired up a KL in a P5 in an afternoon before
                1988 323 GT - B6T Powered
                  Okay thanks. Nice thing about Ohio is no emissions testing. How did you get the probe harness through the firewall? just cut the grommet and force it through?
                    Exactly.
                    1992 Familia GT-X
                    1988 323 GTX
                    2014 Civic Touring
                      @Damkid Did you keep the stock wiring harness in or pull everything and replace it? Like what did you do?
                        What would be the best method of cutting out wires? should I get it running and then cut what I don't need? or visa versa
                          Running first.
                          1992 Familia GT-X
                          1988 323 GTX
                          2014 Civic Touring
                            Alright. Thanks for the help
                              I don't think I removed a single stock wire, lol. It was a mess, but mostly hidden, and it worked well.
                              1992 Familia GT-X
                              1988 323 GTX
                              2014 Civic Touring
