Grandmas 1989 KE Ford Laser!
    Excuse my ignorance.... Microtech ECU?
      Megasquirt! Home made ECU
      All the functionality and features (and more) of a $1000 ecu for about $300
        Very nice! This is one very cool KE!
          No its not! its stock! I swear! (old pic, only thing that's changed is the number plates)
            Plan is to run an MX5 cam angle sensor, with a wasted spark setup....
            Probably the simplest way to control spark timing.
            Of course, the CAS I bought appears to be dead... because nothing ever goes to plan now does it!
              glad to see the build thread. have you completed the wasted spark setup yet? or is this a current update?
                This is where I'm up to.... Sent the dud CAS back on Monday
                  Current mods are as follows:
                  B6t Familia engine
                  EFI fuel tank and lines
                  550x180x65mm FMIC with "custom" piping
                  2.5inch exhaust
                  KYB shocks
                  Lowered springs
                  Whiteline rear swaybar
                  Nolathane bushes
                  Turbo front hubs and discs
                  22v Front calipers
                  Disc brake rear end
                  RDA Slotted and Dimpled rotors
                  Mazda 626 brake booster and 15/16th master cylinder
                  Adjustable steering column
                  SR20 15inch rims
                  Front strut brace
                  Innovate Motorsports gauges
                  52mm thick alloy radiator
                  Louder horn!
                  Still has air con, power steering and the 3 speed auto!
                    its auto???? WHOA props for having the patience to deal with that
                      Auto is the best part!
                      Actually, I have a feeling its dumped half the transmission fluid from the trans sump gasket...
                      I've been considering converting it to the 4 speed electronic shift auto, if I can get the Megasquirt to control it.... more research is needed!
                        Old pics from a few years ago!
                          thats a good amount of flex going there. that after a few years & the poor car will sound like a rattle box.
                          insanity tho!
                            It wasn't in the car for long
                              Few pics of the Innovate Motorsports MTX gauges install
                              One of the gauges.
                              I made some short cables to connect the three gauges together, as the cables you can buy are like 4 foot long! :/
                              I stuffed it all into a jiffy box, with a relay to switch all three gauges on, taking power directly from the battery
                              The whole setup has a hanger to slide it in under the radio, can easily be removed and unplugged if I'm parking in a bad area :p
                                car's looking great! love the gauge placement! that stereo system tho...if your windshield ever leaks you sure know why
