JP Motorsports BG/BF/GT4 Rear subframe production and discussion.
    Also Jim, it sounds as though there is more interest in the trailing/toe/lateral arms that we talked about. Everybody should be chiming in soon with their respective needs.
      Just so it's written down here; as we discussed on the phone, Jim, I am planning OE trailing arms, and your lateral arms.
      The trailing arms don't affect the subframe in anyway, so those can be worked out later.
      1992 Familia GT-X
      1988 323 GTX
      2011 F150 Lariat Ecoboost
      2014 Civic Touring
        Essentially same response as durwood. However if itbis finacailly benficial to the group im in for one set trailing arms.
        1988 BF GTX
        1990 x2 BG AWD Protege
        1991 Escort GT- SOLD
        2005 Corolla
          Cool---I think I'm just going to make all the inner pivot's 1/2" for the rodends---I should be able to drill them out to 14mm when needed.
          sigpicwww.piercemotorsports.com www.piercemotorsport.com Like us on facebook http://www.facebook.com/home.php#!/p...91292610897146
            jim what wall thickness will you use then for the inner pivots? and wouldn't a 9/16" rod end be better suited???
            in the event one of us would want to jump back & forth between OEM & your arms. drilling them out would make this a bit sloppy with 1/2"
              The inner's are 3/4 x .120 which makes a nice 1/2" hole---if some one wants to run the stock arms then it needs to be punched out to the 14mm---they can still switch to my rodend arms, but would require spacers to 14mm rather than the normal 1/2" misalignments we use/which are better/cost effective/easily gotten. The 9/16" would be pushing it I think---the longevity would be the question...
                pardon my ignorance, but will these subframes only work with gt4 rear diffs, or will it still accept the oem 4wd diff.
                NW MAZDAS
                  That's a good question to ask---they're only for the GT4 diff---the stock diff has much different mounting points.
                    Is there a rod end that has a 9/16" hole? That's 14.3 mm, which might be too much play, I don't know.
                    1992 Familia GT-X
                    1988 323 GTX
                    2014 Civic Touring
                      Yes, you can reduce the 3/4" to 3/8"/7/16"/1/2"/and 9/16", but I think your right it would be a bit sloppy for what we're trying to do.
                        a 9/16" misalignment would be fine. .3mm is equal to a good coating of grease lol. you won't notice the play.
                          Hey guys---just checking in. This week we cut the inner pivot sleeves, started making cups for the chassis mounts and started on the dimpled plates for the bottom of the piece. We'll locate a oil drain plug hole in it if we can. I know the size of the bolt that bolts the subframe into the escort chassis (the 4 bolts that literally bolt the subframe in)---I don't have one of the GTX chassis---and the hole looked larger than the BG's---can anyone check the size of that bolt---I'm going to over size it anyways, but don't want to go too big-thanks!
                            I can check some measurements on my protege, or take some pics too while I'm at it if you want
                            1988 323 GT - B6T Powered
                              I'll try and take a bolt out tomorrow.
                              1992 Familia GT-X
                              1988 323 GTX
                              2014 Civic Touring
                                Is it a bolt or stud? If someone can get a picture or diagram pointing out the specific one I'd have no problem getting the measurements
                                1988 BF GTX
                                2005 Corolla
