JP Motorsports BG/BF/GT4 Rear subframe production and discussion.
    I haven't had a chance to actually go and look yet, but it appears the 4WD uses studs with a nut, and the 2WD has a bolt that goes up through. I wish they said the size of the bolts on these diagrams.
    1992 Familia GT-X
    1988 323 GTX
    2011 F150 Lariat Ecoboost
    2014 Civic Touring
      Just for clarification, we are talking about the 4 points that attach the subframe to the body, Correct?
      1988 BF GTX
      1990 x2 BG AWD Protege
      1991 Escort GT- SOLD
      2005 Corolla
        [ATTACH=CONFIG]60395[/ATTACH]
        [ATTACH=CONFIG]60396[/ATTACH]
        I could have told you that Darren lol
        1988 323 GT - B6T Powered
          One of the mount bolts for the rear AWD subframe.... It's a 17mm nut
            that should be M12's
            Where as the FWD's use 14mm bolts [M10] ****(but the holes are larger then a M10 spec)
              If you need to know length my rear subframe is removed from my GT-R
              Stuart
              Sent from my GT-I9300 using Tapatalk 2
                The holes in the subframe I had here had like 3/4" ID sleeves in bushings---we used 3/4" bolts to mock it up...must be some kind of reduction someplace...
                sigpicwww.piercemotorsports.com www.piercemotorsport.com Like us on facebook http://www.facebook.com/home.php#!/p...91292610897146
                  ^ not nessicarily. the FWD's have a location pin for placement. whilest having oversized holes- perhaps the AWD is the same??
                    The bolts measure 12mm. There is no alignment hole in the AWD subframe...
                    Also, in the expanded diagram, if you look , part 28-880 is the reducer that goes over the stud. It's listed as "RUBBER MTG, MEMBER".
                    Here are some pictures of my subframe (still on the car, not coming off any time soon.)
                    interesting hole going nowhere.....
                    --sarge
                      Make one for the BJ/P5 and I'll buy one!
                        Measure up the mounting points, I'm sure they're different, but perhaps the same.
                        Here's the BJ subframe drawing:
                        1992 Familia GT-X
                        1988 323 GTX
                        2014 Civic Touring
                          In my second picture, the front of the car is to the right, this is the drivers-left side of the car. That "interesting hole" seems like it might just be the one used for the FWD subframe mounts.
                          Which makes me think two things:
                          One, I'd like to see if that hole actually lines up on a FWD car. just for curiosity's sake.
                          Two, that they made the 4WD subframe mounts further back for more than just mounting the diff, but also for some needed bracing. If you think about it, with the rear wheels being driven, the front of the diff is going to want to come up. This will in turn put some stress on the subframe to rotate forward, putting lots of load on the rear subframe bolt. Consider the front of the diff to be the lever, the front bolt to be the fulcrum, and the rear bolt to be the load. With the mounting bolts closer together, it gives the diff more leverage on the subframe. With the mounts further apart, it solidifies the subframe a bit and gives it more resistance to forward rotation, hence less strain on the rear mounting bolts/studs, which also happen to be a size larger for the 4WD (12mm instead of 10mm).
                          So, for mounting this in a FWD car, with real power going through it, I think it might be wise to consider somehow strengthening the actual pickup points on the unibody.
                          This is just a thought; I don't know if it's an actual issue, or just my paranoia of breaking things, lol! Granted, this BG 4WD platform was homologated for WRC, so they may have anticipated more loads on it than anything most of us would be throwing at it.
                          --sarge
                            Much different. I don't know much about the GE chassis, so couldn't tell you how much of the rear is actually GE based. Besides that, I'm almost sure that all p5/323f/sp20 share the same awd floor pans so they could save money. I've seen a few underbelly shots of the sp20 and from what I can tell they are the same. Been trying to track down a rear sub for quite some time now. Found this bit though http://www.ebay.com/itm/MAZDA-FAMILI...71074a&vxp=mtr
                              very interesting point to consider sarge!!
                                So where we at here? Is information still needed Jim? If so can I get a reminder of what info is outstanding? I'm feeling quite motivated since picking up my trans this weekend.
                                1988 BF GTX
                                2005 Corolla
