Cluster light problem
    Good day ,
    Suddenly my dash cluster dont light up anymore ... ie Gaz, temperature, rpm, speed everyting else work fine... i know there is 4 bulbs that i have already change a year ago for led ... does anybody knows where to look to fix this problem ... does somebody knows the wires color for this. Already try with another working cluster and still same problem ...
    I have a P5 2003
    Stefan
    check the dimmer switch before you open anything up
      My dimmer switch is working .... my console and others lights are dimming correctly ....
        The only one that are not working are the ones for RPM, SPEED, TEMP, GAZ ... (4Bulds)
          Just to test i took another dimmer switch that is working and still same problem ....
            Is there a fuse you can inspect, reseat?
              all my fuses are ok ...
              Can someone can tell me what is the color of the wire from the cluster responsible to light these 4 bulbs !!! I cant read the wiring diagram
