Berto 24 Turbo build thread
    What size engine is in your car? is it the BP engine 1939cc ?
      Originally posted by FE3-323 View Post
      whats up with the timing belt in that picture? it looks as if its missing chunks
      long story
      Engine
      Trans
      Power
        zm 1.6
        Engine
        Trans
        Power
          Long time since posting here, well after a year of the car being parked finally finally swaped the old engine for another zm-de. Just when I am ready to start it for the first time it woundt start problem was the ecu somehow enter a lock mode for the car being so much time stopped. Now back to the present I got it to start but the car is just giving me hell , the car has a misfire, its backfiring, the idle its ultra high 3-4k rpms, the afr is super lean, so much the gauge goes ------ sometimes it normalize in the 13 area but then goes to ---- again, back and forth. The ultra high idle I solve it disconnecting the vacuum line that goes to the megasquirt, really dont know why that worked. Ok i have replaced coils,spark plugs, spark plug wires and nothing. Another thing the fuel I used has some porcent of ethanol so I was thinking since the car was parked so much time maybe have a cloged fuel pump filter or something. Maybe I need to clean and flowmatch the injectors. Well dont know what more to say..
          Engine
          Trans
          Power
            video, sharing, camera phone, video phone, free, upload
            This is how it sounds like
            Engine
            Trans
            Power
              puede ser los injectores fpr o el maf sensor
              Enviado desde mi iPhone utilizando Tapatalk
                Tengo que ver el flow de los injectores no he verificado eso. La presion de gasolina esta estable en 45 psi y el carro no tiene maf sensor ahora es programable.
                Engine
                Trans
                Power
                  puede ser vacuum leak revisa las tuberías del turbo o sensor temperatura del agua
                    También revisa el tiempo de ignición de la chispa
                      Pero creo que es vacuum leak
                        Regular maintenance is the key to longevity of your forced induction engine. A major cause of stress to all turbo charged engines, especially MAF based systems are vacuum and boost leaks. As a turbocharger feeds air into a leaking system it begins to spin faster in an attempt to maintain the targ...
                        Chequea esta información te puede ayudar con tu problema
                          Conecte el reloj de vacuum bien horita me dio entre 9-10hg de vacuum conectado al manifold se supone que este entre 16-23 cierto?
                          Engine
                          Trans
                          Power
                            según lo que investigue ese vacuum leak hasta forza el turbo y va mu rico en gasolina
                              dale una revisa dita a las tuberias
                              Y aprieta y chequea las abrazaderas
                                No todo lo contrario esta seco de gasolina no se si te fijates en el reloj de mezcla se va mas arriba de 19 y deja de marcar
                                Engine
                                Trans
                                Power
