Berto 24 Turbo build thread
    today removed the oil pan tomorrow hope to take it to the machine shop so that they can weld the oil return line. Also installed the oil feed line it give a bit of a headache but it was all good, and then we cut some parts of the bumper to clear the way for the inter cooler pipes. We are also checking if we will need to move the battery to the trunk that thing is huge and I am 99% it interferes with the pipe that connects with the throttle body.
    Engine
    Trans
    Power
      clearing the way for the pipes
      same
      oil pan removed
      oil feed line
      working with the oil return fitting
      Engine
      Trans
      Power
        good to see more progress.
          I did some progress today cut the bumper for fitting, not an easy job by any means, lol. Also finally installed the inter cooler I pretty much have the all the piping done just need a 2.5 to 2 reducer hose for the turbo outlet, then installed the wastegate and paint the grille black.
          working with the pipes
          when finished it should look like this
          inter cooler ready
          black painted grille
          custom made support plate for the manifold
          wastegate tight fit
          Engine
          Trans
          Power
            yes but the project is in a little hold up because I begin college tomorrow :/
            Engine
            Trans
            Power
              almost there
              Engine
              Trans
              Power
Name:	boost controller.jpg
                Does anyone knows is this diagram is correct?
                Engine
                Trans
                Power
                  that diagram is fine.
                  "Who Dey"
                    thanks btw do you know where can I relocate the MAF sensor dont know where to put it!?
                    Engine
                    Trans
                    Power
                      You can put it on the intake leading to the turbo, or you can do like a lot of people do and put it on the charge pipe heading toward the throttlebody inbetween the blow off valve and the throttlebody.
                      "Who Dey"
                        You will have boost peaks using that diagram. The boost source for the wastegate should be the closest possible of the turbo discharge.
                        The wastegate circuit should be alone and isolated from the rest to be the most precise possible.
                        You could plug your boost gauge on the unused nipple on the center top nipple of the intake manifold. Same place for MS built-in MAP sensor.
                        And for the MAF sensor... delete that sh*t !!! Anyways you wont need it with the Megasquirt; but you'll need two GM sensors. (Intake air temperature, coolant temperature)
                          that the problem when the turbo doesnt have a pressure source port it could been so much easier
                          what about this one better?
                          the hose from the top port of the mbc goes to the pipe that is connected to the turbo discharge
                          I know I am not the best drawer hope you undertand! lol
                          Engine
                          Trans
                          Power
                            first startup
                            Engine
                            Trans
                            Power
                              Its alive!!!!!
                                Easy on the accelerator, adjust that idle screw.
                                Project looking good, pretty clean install. I did not see a wideband anywhere in your parts list.
