Berto 24 Turbo build thread
    Its alive!!!!!
    hahaha about time!
    Engine
    Trans
    Power
      Originally posted by mazpr View Post
      Easy on the accelerator, adjust that idle screw.
      Project looking good, pretty clean install. I did not see a wideband anywhere in your parts list.
      if you refer to the AF wideband I am checking on it in the meanwhile I am counting on a AF gauge
      Engine
      Trans
      Power
        An A/F gauge usually called a "narrow band" is not enough precise to tune your engine right. You could be lucky and tune it right as well as you could blow your engine...
        Think about it. You know the words:"Buy cheap, buy twice!"
          makes sense what about innovate wideband good brand?
          Engine
          Trans
          Power
            I have an Innovative wide band. No issues with it other than a faulty fuse holder. I would recommend it. I like it enough, I bought a second one for my other car.
            1992 Familia GT-X
            1988 323 GTX
            2011 F150 Lariat Ecoboost
            2014 Civic Touring
              Innovate is the way to go AEM is good but more $$
              Engine
              Trans
              Power
                I got an AEM UEGO and pretty satisfied. But my tuner always recommends Innovate because the reading info refresh speed is faster than AEM so it's easyer to tune.
                  new Turbo smart boost controller
                  Engine
                  Trans
                  Power
                    picked up some goodies today Turbosmart boost gauge AEM wideband and Vibrant Intake block this is almost ready!!
                    Engine
                    Trans
                    Power
                      Innovate is the one I got, works very well, just follow the intructions about grounding locations.
                      Buy it when you are ready to mount, warranty is about 3 or 6 months if I recall. I received a bad one, luckily was under warranty.
                      I would have installed the MS first, without any mods, running it stock, but its too late.
                        I was going to get the Innovate wideband but the salesman tell me that he stop working with Innovate beacuse of to much complain about people getting faulty ones so he only sells AEM he tell me np whatsoever with them
                        Engine
                        Trans
                        Power
                          innovate MTX-L are good..... where as the LC-1 are garbage.
                          MTX-L is as close to a AEM uego as you can get.
                            IIRC the LC1 was the one he was refering to not sure why the LC1 is so bad?!
                            Engine
                            Trans
                            Power
                              Checked everything before I handed in it for the tuning and installed the gauges
ID:	1237417Click image for larger version
ID:	1237418Click image for larger version
                              Engine
                              Trans
                              Power
                                Could I idle normally with 750cc Injectors? I know they are big!
                                Engine
                                Trans
                                Power
