GearBox Support ??? G5MXR
    Hello friends, i need help.
    I need to now, how much power (HP) thas the gearbox support (G5MXR) BPT AWD GearBox 323 GTX 1991 and the same think for the rear diferential ?
    this information is very important for me, and my project, But the engine now has 400 HP and i havent test it whit the raer diferential conected.
    Regards for all
    Depends on how careful you are. Some guys blow em up all the time with 180, some can keep em alive for years at 300+, I've blown up a rear end during a rally but teh gearbox lived, and I've blown gearbox and the diff was fine.
      perfect, my idea is .... launch control at 250 hp, later open the booster at 400 hp engine
        probably won't hold up to launching at 250whp. I'd try to swap in a Toyota transmission if you want to launch.
          the gearbox toyota works with the rear differential mazda ???
            you need to use an adapter plate on the transmission and you use the Toyota rear end. more information about the swap can be read on the new Zealand amazd forum or 323gtx forum in the UK. the swap is not easy and takes it takes lots of fabrication.
              i understand, i will use the launch control at 220 hp, but later i will open the booster at 400 hp, in second gear. i will hope dont kboom.
              The gearbox, without AWD connected endured without problem 325 Whp, launching in 2 gear.
