Proud new P5 owner!!!
    Just purchased a 2003 P5 (black) 5 speed
    255k miles. clean interior & a 2nd set of rims with snow tires
    all for $450.
    so far it needs:
    front brake rotors/probably pads
    rear pads
    (which means overall i will be upgrading the braking system- SS lines/ bigger slotted rotors/etc)
    front balljoints & or struts
    a couple potential routes i might go with this yet....
    an oil change
    the inside of the windows cleaned
    a header
    The bad:
    common 3rd gen rear wheel well rust (and a few spots on the corners of the doors)
    needs the front radiator support pulled back just a hair (probably able to do by hand with a few quick jerks)
    headlights are also foggy
    only part of the guage cluster lights work- along with the center console lights
    the heater control doesn't allow full adjustment of placement (i.e. defrost/high-low/feet/etc)
    meanwhile open to all suggestions
    Pictures:
    Sub'd
    1992 Familia GT-X
    1988 323 GTX
    2011 F150 Lariat Ecoboost
    2014 Civic Touring
      sounds like you got a great price on it. looking forward to pictures!!!
        Nice find man! Cant wait to see it in person!
        ~PaTricK~
        -Current car's-
        What are you driving?
          Stick with regular stock replacement matienttence. Let it be your new daily not some overboard project build.
              "if it breaks.... upgrade it"
              thats my motto alex.
              and as of now. the brakes are broken (by my standards) driveable but not safely in my eyes.
                Congratulations on your new car. The P5 is a great model, even stock. I would definitely recommend a Racing Beat exhaust system. A certified power increase and sounds good while not being too loud or annoying. Also, suspension upgrades are easy to implement and make a noticeable increase in handling. Besides the usual shocks, springs and stabilizer bars, also consider a lower front end tie bar. The P5 already has a front strut tower bar as a stock fitment.
                Have fun.
                  Subn...... Mmmmmmm subs
                    bump to the top! pictures updated in the first post!
                      Hot damn thats some rust lol you have alot of work cut out for you
                        thats not horrible in actuality for a BJ chassis. and the underside is in much better shape
                          +1 Welcome to the world of paper thin cheap recycled metal
                            Jeez I'm glad CO doesn't salt. They dump magnesium chloride like there's no tomorrow, but as long as you rinse your car after every snow storm it doesn't harm them.
                            But, I'm subbing for updates. I like the p5's!
                            Current:
                            68 Torino GT Fastback
                            86 MR2
                            91 F150
                            94 Escort Wagon BP swap
                            99 Escort Wagon BP swap
                            00 Miata LS
                            08 Arrow AX8
                            14 Mazda5
                              Subbd' also I have a right rear tokico illumina brand new only opened for test fitting purposes(didnt fit what I wan5ed) $100 shipped ...that is if your looking.
                              1988 BF GTX
                              1990 x2 BG AWD Protege
                              1991 Escort GT- SOLD
                              2005 Corolla
