so installed a stainless steel race header all went well both 02 sensors went right in exhaust bolted right up ,however am having a problem with egr tube... the place to mount it is there, but tube is at different angle and not quite long enough.... don't want to relocate inlet think I can cut tube and put in a flex tube so I can swap back to stock cat set up when need to do smog,got to love cali!!!lol anyone know where to find that kind of flex tubing???
local hardware store. or your large chain stores (lowes/home depot/etc)---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Well.... egr isn't. Required. Mines not even connected to the manifold anymore. And no cel
Perhaps you can just weld shut the manifold side. & leave the egr be---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Dtc??---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
any pictures of your install? I left mine open with the threaded portion cut out of the stock manifold & just hanging there ( no codes as of yet )---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by pain4all View Postno I can take some of it installed tommorow tho and sho you ,how do I get pics in gallery?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
