Can anyone confirm that the front spindles on a BG base model 323 and a Protege LX are identical? I'm getting ready to downsize the brakes on my autocross car to the smaller 323 9.25" disks and hopefully Wilwood calipers. I have my old Protege LX spindles/brakes on it right now. My 323 spindles are on the Protege which is at the fab shop getting the cage welded in it. If the spindles are identical I won't have to go swap them out.
323 vs Protege Front Spindles
pro LX spindles have the brake mounting slightly further outwards in order to accommodate the larger brakes.
so no not fully the same.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
no worries---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Calipers
Originally posted by XelderX View PostCan anyone confirm that the front spindles on a BG base model 323 and a Protege LX are identical? I'm getting ready to downsize the brakes on my autocross car to the smaller 323 9.25" disks and hopefully Wilwood calipers. I have my old Protege LX spindles/brakes on it right now. My 323 spindles are on the Protege which is at the fab shop getting the cage welded in it. If the spindles are identical I won't have to go swap them out.sigpic
Originally posted by protege94 P.R View PostWilwood calipers are bolt on or you have to fabricate something?
