Just do the bg gtx trans. Be reasonably nice to it and it will live. I ran more than that through mine pretty successfully and will some day again if ever I get time to finish installing turbo and manny and dp and and and and......
Celica GT4 trans in a BF?
Okay, firstly, as a matter of fact the GTX gearbox is weaker than the BFMR version if anything, so I don't know why on earth you would change to that. Secondly, I'm looking at doing the same thing, I originally wanted to go for the ST205 box, but after a little more research found out that space might be an issue. However, you can get a shorter version from the toyota RAV 4, which does unfortunately have narrower gears, but has to be tougher than the mazda box! I've heard its still fine for around 300KW ATW, so with the light BFMR Im planning on going down this route, worst case can always look at going celica further down the track anyway as all the other mods needed to fit it are the same.
So, AFAIK, its going to be pretty similiar to the BG conversion, except I'll be going to GTR hubs and I'm wondering if the angle/position of the engine is going to change much, as I am extremely limited on space as it is, don't even have the room for a raidiator fan haha.
Does anyone else have any thoughts on the matter? Any input would be much appreciated!
Cheers
Dan
The angle of the engine shouldn't change much using the proper adapter plate for the transmission, in fact I read somewhere that the celica axles bolt right in but you need to do something about the intermediate bearing. Still going to have to cut into the pan if you stay strictly ST205 but if you use the rav4 t-case you may not have to. I will look up a few things for you bear with me.Not What you build, But HOW.
Rallycar egine sits about an inch higher and less than that forward and we pushed it all back to the firewall to the point of losing the speedo cable housing.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
Here you go referring to the rav4 t-case swap, take note in the difference in size from the st205..
And on my page a few things to look at for a quick read... Don't mind the posts about my hand it has finally healed and I am getting back on track with my build, just got to take care of a couple of funerals first.
If you want the rear propshaft to come out nice and straight, which I did, that is how it has to sit.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
Hmmm interesting. yeah I knew you could use the stock celica shafts, hence needing the bigger hubs. Modified Prop shaft with celica ends. I didnt think you can use the rav 4 transfer on the 205 gearbox though so thats interesting, I thought due to the output ratios it would basically end up toast. Not so much the bolting up of it.... More worried about whether the box will actually FIT between the chassis rails. Cheers for the info will have a read tonightLast edited by WRCBFMR; 12-10-2014, 05:49 AM.
The center differential ratio is the same in the first generation rav4 as the st205 you can take the rear differential and bolt it straight into the first generation rav4. All GT4 diffs have the same ratio to. just to clarify, and the second gen ie 2001 to 2005 will bolt up to but you have to tear everything apart to get a good final ratio damn things are low geared.Not What you build, But HOW.
They're the same housing different setup. You read them at all? It's actually quite easy. Take a camry/solara v6 E153 transmission making sure they have the 1MZFE engine from mid 90's or later, and take a first gen rav4 transmission and pull them apart. Put the final ring gear from the camry/solara and install it on the rav4 E250F front/center differential and putting it all into the camry/solara box and slide the rav4 transfer box on pretty much your done, recommended to replace all the bearings while your in there oil seals etc etc. Read the full site regarding the awd swap you will understand from the e-series transmission.Last edited by Pashka0788; 12-12-2014, 02:53 AM.Not What you build, But HOW.
