Mazda 4wd backend - prep, colour application, Torsen diff fit up & installation.
4WD BJ Familia
nice update!!! subbin for more progress pictures---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Custom mounts installation and slotting of chassis leg currently on hold due to fabricator busy schedule.
Acquired some additional goodies for my car though.
Evo ecu 8 setup courtesy of Carlos Rivera from BP Performance. Just need to acquire the tach adapter, Evo map sensor with adapter. I had a set of Evo 8 560cc injectors, so I had asked Carlos to add some Bosch connectors instead of the Denso connectors to the custom loom.
Scored me a set of really low milage (600 mile) BC coilovers @ an awesome price.
nice scores!!! you'll like the evo ecu! it really changes the game---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
This is how I kicked off my 1st day in the New Year. Got the engine and Gt4 Celica gearbox mounted (mocked up) in the engine bay today courtesy of Delroy Henry of 360 Weld. Thanks to Teyhren Ramdon for granting us access to Finishline Auto on New Years day public holiday. I felt like a child unwrapping his present on Christmas morning as I removed the blocks and boards that were used to support the engine and gearbox in the engine bay. Bolted up engine side & top gearbox mounts, slotted the chassis some more and fabricated the top gearbox mount bracket. Have the front & back mount brackets to remaining and to modify the subframe so that Celica axles can clear it.
Weekend #1 of the new year: Got some more work done on the car yesterday. Fabricating of the front mount bracket and finish welding the top gearbox mount bracket. Fabrication done by 360 Weld Delroy Henry. Have the back mount and notching of subframe so the inner cv's of the Celica axles can clear the and install in the gearbox. #WTF323 #Finishlineauto #360Weld #TMF
Fabrication of front mount bracket.
Onto the top mount bracket. Removal of mocked up bracket to weld properly.
Done and painted.
Almost there. Looking so unsuspecting. It's not what's on the outside, but what's on the inside that counts. This is the first 4wd 2000 - 2003 Mazda 323/Familia/Protege (BJ chassis) with the Toyota Celica GT4 4wd drivetrain conversion on a global level. #WTF323 #TMF #Finislineauto #Nestechweld #360weld #4wdfun #BPturbo #E154F #Mazda #Yota #ZoomZoom
nice work! its coming along!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
