I have to get rid of this wish I had the room and time to finish it. Take it all for $1500. Or $1000 for BPT with new fresh piping and front mount. Will include the trans and axles for additional $300 if buying just motor. The shell is clean and no rust, but small dent on passenger fender and cracked windshield. Has upgraded turbo, Will come with square headlights and front end as I used the parts on my sedan. Stock rims with newish tires (>5K miles). Stock suspension with cut coils. Located in Ventura County.
93 323 with BPT (So Cal)
Not bustin yer balls or even commenting on the price. The VJ11 has the exact same compressor specs as the VJ20...not much of an upgrade at all. The only difference is the VJ11 R20 turbine housing a/r and it is a bit larger as it was used on the 2.2 vs the 1.8. Laggy on the 1.8. The better upgrade would be the Tbird or VF10 or 11 compressor on the VJ20 R15 housing...at least in the IHI RHB5 family. Curious on what you did to mount the VJ11 on the BPT exhaust manifold.
Would buy this if i had the funds.Proud owner of way to many!: (Click one to view)
1994 Ford Escort LX White (The Original)
1991 Ford Escort GT Red (The Main/DD)
1993 Ford Escort GT White (SOLD!)
1990 Mazda Protege 4WD White (New Toy!)
1991 Mazda Protege 4WD Blue (Turbo Parts car for the White one)
1994 Mazda Protege DX White (Parts car for the White 4WD)
Originally posted by azgtx View PostNot bustin yer balls or even commenting on the price. The VJ11 has the exact same compressor specs as the VJ20...not much of an upgrade at all. The only difference is the VJ11 R20 turbine housing a/r and it is a bit larger as it was used on the 2.2 vs the 1.8. Laggy on the 1.8. The better upgrade would be the Tbird or VF10 or 11 compressor on the VJ20 R15 housing...at least in the IHI RHB5 family. Curious on what you did to mount the VJ11 on the BPT exhaust manifold.
solid deal tho, someone should jump on this.Last edited by atomicEGT; 08-14-2014, 08:38 PM.sigpic
Still plannin on sellin this? or is it gone?Proud owner of way to many!: (Click one to view)
if he parts it out I call dibs on the spoilers93 323, 94 MX-3, 04 MSM, 83 Jeep Cherokee, 87 b2000
www.gunshowracing.com
