Looking to clear out some unneeded parts and make some room in the garage. First one to put money in my PayPal gets it, no dibs.
First up, shifter and cables from BF GTX. Everything is still solid, bushings are in great shape. Sold!
BF GTX AWD transmission. Removed from my running car with 140,xxx miles. Always shifted smooth with mild clash near redline into second gear. Fluid was extremely old and dirty, should be fine with new fluid. $200 (pick-up preferred, but will ship at buyer's expense).
BF GTX oil pan. No cracks or damage. $60 shipped.
BF GTX B6T rods and pistons. Removed from the same GTX as the above listed trans. Good shape, but could use a good cleaning and new rings. Sold!
BP tubular manifold and downpipe. Heat shield tabs have been removed and ground smooth for a cleaner look, then sandblasted. I planned on having it ceramic coated before I decided not to use it. Downpipe is pretty well junk, but the flanges are good. $100 shipped in the US.
BP fuel rail with injectors (one pintle cap and spacer are missing). All plugs are intact. Removed from a running car, but has been sitting for several years. $60 shipped in the US, and I can have them cleaned and flow tested for an extra $75.
KL starter for manual trans. Worked when removed from the car. $45 shipped in the US.
BF AWD jack shaft. $65 shipped in the US.
BG G series axles. Auto Zone reman with a lifetime warranty, roughly 4k miles on them. Upgraded to Kia axles and no longer need these. $120 for the set shipped in the US.
BP n/a intake manifold. Super low miles (under 10k), only missing VICS actuator. $55 shipped in the US.
BG Drop Zone coilover sleeves. Brand new, only opened for pictures. The box shows 2 wrenches but there's only one inside. Sold!
BF GTX VAF. Unopened, worked perfect when removed from the car. $45 shipped in the US.
Brand new inner tie rod for NON-v6 mx3. $20 shipped in the US.
I think that's everything. The best way to get a response from me is through PM, but I will check this thread as often as I can.
