Help me pass my etest and fix my odd idle
    Idle sometimes behaves then other times it just starts moving up and down
    I have attached a log that shows the problem
    no intake leak putting the air filter right on the tb doesn't change anything
      msq
        Need moar info on your setup but if you are on a map, erratic idle is almost always a fuel map issue. This is assuming everything else is shipshape. i've dealt with, let's see...5 different standalone ECU's now and none of them are really good at just getting adle down without having to babysit them. Even if you flatten out the idle curves, if the O2 sensor doen't like what it smells, the ecu starts hunting across rows and sometimes columns, and does what you describe. So you get to go into the table and futz with it til it behaves. The fact that it doesn't always do it implies that not all else is shipshape however. air leaks can happen after the TB.
          Bp turbo with the 330 cc injectors
            So what, everythinv else stock? ecu, maf and all? If so then it's almost certainly an air leak somewhere twwen the maf and the head. I can't look ag your zip files at the moment cuz my file opener is ***ing at the moment...
              Stratified MS, GM IAC
              everything else is stock
                Prolly fuel map, and that can be a real PITA to fix. I got the ralycar to behave by the simple expedient of bringing it to an AWD dyno shop with staff who knew WTF they were going. I plan on saving time with the street car by taking it to the same outfit once it's up and running.
