Info on installing the lauch control on the MS2 from stratified.
I actually sent them an email about 3 hours ago asking if I can run a wire from the internal connector block [clutch switch input from factory loom] to the clutch switch header and have it work like that. Will let you know if/when they get back to me.
I got a response from Stratified about the clutch switch. If you're running the PnP GTX ecu [probably on the GTR one too] it is already wired up to your factory clutch switch. So just turn on launch control/flat shifting and start playing with values.
