Ultrasonic injector cleaning, flow-testing and service kits
    I feel that I am finally ready to offer injector cleaning services to the members of Clubprotege, after spending some time learning to use the machine and trying different sets of injectors with it. Due to some limitations on my end and limitations of my machine, some things need to be noted:
    1: I only have a very small stock of injector service parts, so full service can only be offered on certain injectors, which are anything I already offer kits for.
    2: Due to the limitations of my machine, I will not be able to get accurate flow data for injectors of 450cc or larger since the test tubes will overflow. If this happens I will manually stop the machine at 5 sec and calculate the flow instead of the standard 15sec set time the machine uses. This is not accurate due to me not being able to stop the machine in the exact same place every time.
    3: No side feed injectors can be currently serviced.
    4: I may not have the required adapters to do a back-flush on all injectors
    5: Any problems or limitations with my service will be notified by PM or email, and the appropriate action taken. Price adjustment, partial refund etc....
    6: Flow bench test will be done 3 times before and 3 times after service. I calculate the average of the 3 runs to determine flow rating due to variables in the machine, fluid, and fluid temperature.
    Pricing:
    Full injector service pricing will be $14 per injector + $5.50 return shipping.
    Injector cleaning only will be $11 per injector + $5.50 return shipping. **No service parts replaced**
    A full set of injectors (4+) will include return shipping at no additional cost.
    Full injector service pricing for locals will be $13 per injector
    Injector cleaning only price for locals will be $10 per injector
    Injector service details: ***Full service only
    Check coil resistance
    External cleaning
    Flow bench
    Remove Service parts***
    Two 20-minute ultrasonic cleaning cycles
    *Cycle includes injector held wide open and pulsed
    Back flush injector***
    Flow bench
    Replace serviceable parts***
    Bag/number all injectors and old service parts
    Before/After results printout
    Shipping and payment:
    PM me for my shipping and payment information
    All injectors should be completely dry of fuel and bagged for shipping.
    I recommend using USPS small flat rate boxes for shipping
    Please include your return address and screen name in the box so I know who they are for when they arrive.
    Payment can be made by paypal once the injectors are ready to be shipped back. I will send a PM when they are ready.
    I will send a PM with a tracking number after I receive payment.
    Please allow 1-2 business days for injectors to be serviced before expecting a PM for completion of service.
    Let me know if there are any other questions you guys may have.
    FS Forged H beam rods
    awaiting test fit
    Aluminum CAS/Distributor caps
    BP oil jet eliminators
    EV14 fuel rail spacers
    More stuff coming soon.......
    The M1 kits will cover the following cars: Miata, Escort GT, Protege/323, *RX-7*, MX-6/626, Capri, Toyota pickup/4-Runner etc.........
    IF you dont find your application listed above but your fuel injectors look like the one pictured below regardless of the color, the M1 kit will fit it.
    The M1R kits will cover only *RX7* injectors.
    <<<<If your RX7 injectors have a 7.7mm tip then you need the M1 kit>>>>
    >>>>If your RX7 injectors have a 8.7mm tip, then you need the M1R kit<<<<
    What's included in the kit:
    M1, M1R:
    O-ring
    Spacer
    Filter
    Lower seal
    Pintle cap
    Pricing:
    M1 kit: $2.03
    M1R kit: $1.97
    Order 4 kits to make a set and get 10% off:
    M1 set: $7.31
    M1R set: $7.10
    Individual pieces available: PM me for a price quote
    Shipping:
    U.S customers: Flat rate of $5.50 as long as it fits in the box. Priority Mail
    Canadian customers: Flat rate of $8.50 as long as it fits in the box. First Class Mail
    Canadian Priority Mail: Flat rate of $21 as long as it fits in the box.
    Local pickup is available to avoid shipping.
    Payment:
    PayPal/check/money order for online orders
    Cash/check/money order for local orders.
    Pm me to place an order.
    Please be clear if you post or PM what you want:
    Kit or Set part# and the quantity that you want and then I will be able to give you a total price with my payment information.
    See the following posts for more kits/applications
    awaiting test fit
      The M2 kits will cover the following cars: Miata, Kia Sephia, BH Protege, RX8, Top Feed Subaru WRX, Camry, Solara, Sienna, HS250H, RX330, RX400h etc........
      IF you dont find your application listed above but your fuel injectors look like the one pictured below regardless of the color, the M2 kit will fit it.
      M2:
      O-ring
      Spacer
      Filter
      Lower seal
      Pricing:
      M2 kit: $1.62
      M2 set: $5.83
      Shipping:
      Payment:
      awaiting test fit
        The M304 kits will cover the following cars: 3, 5, 6, MPV etc................
        IF you dont find your application listed above but your fuel injectors look like the one pictured below regardless of the color, the M304 kit will fit it.
        M304:
        Upper o-ring
        Lower o-ring
        Pricing:
        M304 kit: $2.14
        M304 set: $7.71
        Shipping:
        Payment:
        awaiting test fit
          New kit and applications coming soon for this style injector!
          awaiting test fit
            New kits and applications coming soon for 3rd gen protege owners and other cars that use this injector!
            awaiting test fit
              The K6 kits will cover the following cars: MX-3, MX-6, 626, Millenia, Mellenia S, 929, Probe
              IF you dont find your application listed above but your fuel injectors look like the one pictured below regardless of the color, the K6 kit will fit it.
              K6:
              Upper O-ring
              Filter
              Lower O-ring
              Pintle cap
              Pricing:
              K6 kit: $9.05
              Order 6 kits to make a set and get 20% off:
              K6 set: $43.44
              Shipping:
              Payment:
              awaiting test fit
                The ZVH19 kits will cover the following cars: 91-03 Ford Escorts with 1.9/2.0 SOHC and DOHC
                IF you dont find your application listed above but your fuel injectors look like the one pictured below regardless of the color, the ZVH19 kit will fit it.
                ZVH19:
                Upper O-ring
                Filter
                Lower O-ring
                Pricing:
                ZVH19 kit: $1.81
                Order 4 kits to make a set and get 15% off:
                ZVH19 set: $6.16
                Shipping:
                Payment:
                awaiting test fit
                  Anyone interested in kits for KL injectors? They would fit all KL injectors including Millenia S injectors.
                  awaiting test fit
                    K Series V6 injector sets are coming November 3rd. See post 7 for pricing information.
                    awaiting test fit
                      I am now able to service side feed mazda and nissan injectors if anyone is interested.
                      awaiting test fit
                        1.9/2.0 Escort kits added, check post #8
                        awaiting test fit
                          Fellers..take James up on this service if you are in need.
                            So reading your first post it says you couldn't do anything for side feed injectors but later on you've added them to your list of options, does that include checking the flow rates?
                            1988 323 GT - B6T Powered
                              I can do full service on KL side feed injectors, so checking flow rate and replacing all service parts. O-rings/pintle caps/filters.
                              Nissan injectors would have to be flow only since I don't have the service parts for them.
                              awaiting test fit
