no start, no crank, no anything!
    This 1991 Protegé (mileage 85,000 miles / 140,000 km) wasn't used for about 3 months, and now, it won't start. The battery (NOT orginal) probably drained. The battery shows only 5V across the terminals, so I tried jumpstarting it, but nothing happened. (Not even the dome light turns on; no accessories at all).
    I called AAA (CAA), and they used a portable battery to jumpstart it, but nothing happened. Analysis of the battery showed 475 CCA on the battery, which according to the technician *should* be enough to try to turn the crank. He suggested something else is wrong.
    I'm afraid that simply buying a new battery won't solve the problem.
    Usually, when there is starter failure, you would normally hear a click, but this car does NOTHING... which suggests, unless I'm mistaken, that there is an electrical problem, other than the battery.
    An examination under the hood reveals nothing obvious to a non-mechanic. Looking at the fuse box under the hood, however, reveals one blown fuse. Please see pics attached and help me identify what this fuse is for (the third from the left, across the top row), what the fuse specification is, and whether it is critical for starting the car. I haven't been able to find a fuse box diagram that helps me.
    I would have had the car towed to a mechanic, but the problem is that it is currently parked in an underground parking garage, and the entrance gate is NOT tall enough to allow a tow truck to enter.
    Not sure on what fuse it is but it is likely the cause. Probably will not need a mechanic.
    "Who Dey"
      That is the main fuse. It's rated at 80 amps. Everything has to pass through it. Check your starter connections for a short, and replace that fuse.
      1990 Protege 4WD
        me109, thanks for helping. I was afraid of that fuse being critical. As it turns out, I can't even pull it out, as it seems to have melted to join the fusebox. Any suggestions? Will I have to replace the whole fusebox?
          It is held on by one or two nuts that you can't see until you pull the box out.
          1990 Protege 4WD
            1. Is there a technique to pulling out whole the fuse box? It's not clearly obvious (to me, at least, one who does not spend enough time with his head under the hood).
            2. How much should a replacement main (80A) fuse cost, roughly?
            3. Where is the starter located in a '91 Protegé?
              that fuse looks like it was soldered together.
              fuses can be bought at your local part store for a few dollars a piece. If your fuse looks like that I HIGHLY encourage buying a couple. This fuse does not usually blow unless there are other problems in the wiring.
              Have you found any signs of mice activity??
              2 10mm bolts hold it in place(both the box & the fuse) for a grand total of 4 10mm nut/botls
              replacement is exceptionally easy so your in luck there.
              These pictures should help guide you.
              the second 10mm bolt is hidden behind a plastic flap on the back side of the fuse box you'll see it once you remove the box.
                Progress! Thank you so much, FE3-323! Your guidance ever so helpful in removing what was left of the main fuse. Easy enough to remove, but I'm not sure I would have known to check for that bolt behind that plastic flap, had you not told me to.
                Looking under the car, I see some spider webs. I'm pretty sure there aren't mice in this relatively busy parking garage, but it's not impossible. Wiring near the fuse box appears to be intact (no mice activity). Where else should I check, exactly?
                I hope to find a replacement fuse today, and before installing, I hope to check the starter connections. To do that, do I need to get under the car?
                  eh jsut throw in the fuse & see what happens :D
                    Look for shorts near the 'big three' electrical devices. That's starter, battery, alternator. Also, if it has some kind of aftermarket amp or other user installed device, disconnect that just to be safe.
                    1990 Protege 4WD
                      eh just throw in the fuse & see what happens :D
                      So, I threw in the fuse, and....
                      still, nothing happens.
                      With a new 80A main fuse, I still don't get any electrical signal whatsoever. Turning on any accessory does nothing, turning the ignition produces no other noise or activity.
                      The voltage across the battery terminals is only 4V, but should not yield being able to turn on the dome light or the radio or something insignificant?
                      Any suggestions on what to troubleshoot next?
                        4v is really too low to do anything.
                        the interior fuse panel has an engine fuse too. double check all interior fuses as well.
                        you might consider a new battery
                          You might consider stepping up to a 9-volt battery.
                          1990 Protege 4WD
                            Update: I purchased a brand new battery and replaced the dead one. She starts! [In hindsight, I should have looked for a used one to save a couple of bucks. However, I was afraid of the problem being more severe, and I wanted to eliminate the battery as an issue.] Thank you very much to me109 and FE3-323; you were extremely helpful, and I am grateful.
                              glad to help!!
