1988 GTX Restoration - Going To Be Fun!
    Originally posted by Mr Rotary View Post
    Front please
    If you can wait until tomorrow, I will snap some good pictures for you after I pick it up from my powdercoater. For the GTAe (front) bumper the bracket is three (3) pieces but "tied" together with fasteners.
      Of course I can. Thank you
      '88 GT
      '88 GTX
      '85 Toyota Cressida 5-Speed
      '88 323 GT
      '88 323 GTX
        So Yasin, how did you come up with that fabric pattern in those seats? They look to be one of the Euro / JDM types.
          I bought the bumpers and interior from Piotr. What a trek across the world for these parts.
            Nice.. And a trek across the wallet as well. Glad I am not the only sicko lol. We are gonna have to keep these cars until the end of time to get the $$'s worth out of them huh. Nice.
              Agreed! Sicko is an understatement! Gotta to drive 'em and enjoy 'em brotha!
                Fairly productive day.
                I made a new Intercooler to Intake Manifold aluminum pipe and mounted the HKS SSQ BOV valve. I also picked up the valve cover from the powder coater and the red wrinkle came out much better than I thought.
                Before:
                Making the new intercooler pipe:
                After, all welded and polished and red wrinkle valve cover installed:
                As requested Mr. Rotary, GTAe front bumper bracket:
                  so much going on it that engine bay!!! the valve cover & new pipe look good! nice work
                    That is one down side point on these cars is the vast clutter in the bay. Going with a bp swap and a stand alone with a battery relocation gets rid of all of the harness do dads and opens it up. But we do deal with it using other focal points.
                      That's ironic, that you say its "busy", I was thinking quite the opposite, with the AC removed and the JDM / Euro manifold, I find that working in there access and following lines and wiring fairly straightforward. With the car's age, I could also clean it up by removing the EVAP system and associated lines.
                        Go for a wire tuck, breh.
                          I already did a tummy tuck, so have no funds left for a wire tuck breh.
                            No a/c in a Houston car...winter cruiser huh. Can't get much into June here with my white GTX with no a/c. The black one does though and I just converted it to 134A so I will see if it can keep up as the R12 did. Being the we know where and what all the wires are for I can see your point....just the open the hood and geez factor still gets to me.
                              When I bought the car, the AC components were removed (maybe the car did not originally come with AC) and I am not sure how much trouble and $$ I want to spend on retro-fitting AC, as you know it has been adding up quickly. In Houston, basically from June to September is when you need AC, the rest of the year is bearable.
                              I am running R12 in my GT and so far the car does really well in the middle of our extreme heat.
                              Yasin
                                Yep r12 is fine. It is just when you retrofit the 134a into an r12 system the condensor is not adequate to keep up. It will cost about 5-8 degrees....not so bad but gas is readily available which is a plus. Putting ac in the car is pretty easy really. Might cost you 600-700 if you do it yourself with new parts. You have choices with your stable.
