Anyone running a lt10 on a bp? Please need a map for water temp correction setting will appresiate your help with ghis matter is giving me hard time to start!!! After start the car is running very good only problem is for starting ghe engine
Microtech lt10 help
what water temp sensor are you using?
I know the OEM BP temp sensor info is around here somewhere.
I used these back when i had a megasquirt
-20 - 16200
20 - 2450
80 - 320
CTS thermo table
couldn't tell ya what the right side number increment was but yeah---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
