Microtech lt10 help
    Microtech lt10 help
    Anyone running a lt10 on a bp? Please need a map for water temp correction setting will appresiate your help with ghis matter is giving me hard time to start!!! After start the car is running very good only problem is for starting ghe engine
    Up!!! Nobody!!!!
      what water temp sensor are you using?
      I know the OEM BP temp sensor info is around here somewhere.
      I used these back when i had a megasquirt
      -20 - 16200
      20 - 2450
      80 - 320
      CTS thermo table
      couldn't tell ya what the right side number increment was but yeah
        I am using the stock oem coolant sensor
