Brake upgrades part 1: developing an OEM size 2 piece brake rotor
    This thread will give details and serve as a discussion spot for the 2 piece rotor upgrade I have been working on. The other thread I had was starting to get confusing since I talked about so many different things.
    Why a 2 piece rotor and what are the benefits?
    #1 reason and the most important is weight savings. This rotor has the potential to save a minimum of 3 lbs per side compared to standard BG 10" rotor. This would be like putting lighter weight wheels on the car and since its unsprung weight like the wheels are, it has more benefit than removing sprung weight from the car.
    #2 reason is better heat dissipation and less chance of warping rotors if you overheat the brakes since both the ring and hat can expand independently of each other without stress.
    FS Forged H beam rods
    awaiting test fit
    Aluminum CAS/Distributor caps
    BP oil jet eliminators
    EV14 fuel rail spacers
    More stuff coming soon.......
    awaiting test fit
      Reserved2
      awaiting test fit
        I sent you a message on Facebook. Lock me in for the first set out of production or a test set...give me something as soon as you can. I've been planniong on doing this to the autocross car for over 2 years now. I need to get some testing on it and make sure it's solid before Nationals in September.
          Also....
            I saw your message just now. I currently have a quote from a manufacturer in China to build them, but the quantity would have to be at least 50 pieces, at $50 each. Another company will do a lower number but the price will obviously go up. This really is the only thing holding me back right now is the lack of interest. This is far cheaper than anything Wilwood has.
            awaiting test fit
              Do you have someone local doing the prototypes? If it doesn't work out I would be willing to send you some money for the CAD files so I could get some made.
                The stuff I had pictured was 3D printed in PLA plastic just for test fitting by a guy I found on Craigslist. I need to have the same guy revise some of the dimensions for me since I found some fitment issues with the ones I have.
                How much do you think your guy would make them for?
                awaiting test fit
                  I might very well be interested, pending some more solid price figures.
                  1990 Protege 4WD
                  1 3 5
                  2 4 R
                    Well if we can get 10 people at $50 each for a deposit and $50 upon completion then I will go through with it.
                    awaiting test fit
                      If you want, you can email me the drawing and I'll see how much I could make them for.
                      --Ferdi
                        A detail I forgot to mention is that they quoted me that price for the hats to be made in 7075-T6. Wilwood hats are made in 6061-T6
                        awaiting test fit
                          is this $50 per corner, i presume? for a 2 piece rotor? that's a helluva deal if so.
                            No that price is only for the hats per corner. You buy the wilwood rotor and hardware kit.
                            All said and done you would be into this for $250 which is about half the price you would pay for a similar setup with wilwood hats and wilwood does not make a hat that would work for this application.
                            awaiting test fit
                              Ah. Ok. I haven't look at the big brake kit threads for 'a while'. thanks for the clarification
