5 speed tranny starting problems
    Hi ok I'll try to ask my question as good as I can, I can start my 94 mazda protege without the clutch engaged and in neutral, when I put in the clutch and try to start it won't, maybe a little crank like it wants to start, is my tranny bad? I was told that the clutch master and slave cylinder was bad so replaced that and didn't do anything. Any help would help thanks, I bought the car this way.
    Not enough info. when you try to start with the car in gear and your foot on the clutch a d it doesn't start, does the car try to lurch forward on the starter motor? then the clutch isn't disengaging. If it doesn't try to move at all, and the parking brake is not on, then all you might need is to adjust the clutch safety switch a bit.
      Ok it seems that the wheel moves a bit but not much also, also how is it able to start in neutral with out pushing in the clutch, and where is the clutch safety switch located?
        clutch safety switch is on the back side of the clutch pedal.
          hmmm yeah if it starts witbout having to put the clutch in then that sounds like that switch (which is pretty much on the clutch pedal up high under the dash) is not the problem and is probably not working at all. It could be that the neutral switch on the trans is causing the problem. I think they had that item on these cars by'94 but am not certain. What happens when you pump on the clutch pedal like a madman and then try to start it with the clutch engaged? And how does it drive once it's fired up? If it goes into gear with the engine running then the clutch is disengaging as it should and your hydraulics are fine. If not then not. If it goes into gear and drives fine then your trans is OK and this is a switch gremlin.
            Thanks for the answers, I'll have to look into later also engine runs fine its trying to put it in gear and move it.
              Why not bypass the clutch interlock altogether. Then it should start whenever you turn the key, no matter what. That is pretty much what I did.
              1990 Protege 4WD
                watched a Saturn slam into a toolbox at Firestone one day because the dude's clutch switch didn't work and he didn't tell the tech.
                that **** is there for a reason.
                  You need to finish your process, the master and the slave need bleeded. If you can't get the car to go into gear with it started, its because your slave cylinder is not pushing the throwout bearing and shift fork far enough in. This is why your car will try to move with it in gear and you try to start it. Also, it seems that your clutch switch is probably bypassed.
                  "Who Dey"
                    Clutch switch is bypassed. Its soldered and tucked under the carpet. Or was when I owned the car.but like others have said, you need to completely bleed the system.
                    -Steve
                    94' Protege < Worklog<SOLD!
                    VF10 powered!
                    262 Whp & 257 Wtq
                    13.1@107
                    '02 Suzuki Bandit 600s
