Hey guys. I have a knock controller off a bp26 and a knock sensor off of a bpt motor. The wiring is different colors on both and my dilemma is figuring out where each wire will be headed to for its proper location. Not sure which colour will be the ground or positive as well which wire will run to the sensor and which will be going to ecu? I have the bp26 pin out for my ecu so I know where the wire will be headed for the knock controller just need to figure out which wire from the controller. Any help is appreciated and if there is somewhere I can find this info point me in that direction. Thanks guys.
Bp26 knock controller wiring colors
righto!
glad to be of help either way.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
