I want the fan motor that goes in front of the radiator. It is a flat little motor. Is this an item that is available aftermarket?
I replaced the fan motor behind the radiator. I got it from the local Carquest. It is getting me by for now but summer is coming and it will be above ninety degrees for most of the time until fall.
Thanks in advance if you can point me in the right direction.
