JDM 4WD trans 5th gear cover reaseal in vehicle? Taller 5th gear?
    Has anyone resealed the stamped black metal cover over the 5th gear sets on a J Spec 4wd transmission in car? It looks like a tight squeeze, but mines leaking and really don't want to remove the whole thing just to reseal it.
    Also, is there any 5th gear sets that are taller (like the 626 gear sets for the BF G series transmissions) that drop into these boxes?
    Mazda
    1988 Black 323 GT
    DOHC 16 VALVE TURBO
    2013 Velocity Red Mica Mazdaspeed3
    Take it off and seal it. No big deal there. Yes .717 and .755 gears drop in.
      Dmnit, this was supposed to be in BG. Not BF, sorry. This is in a 4wd Protégé with a GTX drivetrain (BPT) Does the post above still apply Clay?
      Mazda
      1988 Black 323 GT
      DOHC 16 VALVE TURBO
        Partly....your tranny already has the .717 gears in it...pull the pan and reseal it.
          Odd. The gearing to MPH to RPM ratio seems closer to the BF GTX trans. With the gears I got from you a few years back for my GT, I was sitting around 6900 RPM at 70 MPH. This one Im hovering 72-7300RPM at 70...
          Mazda
          1988 Black 323 GT
          DOHC 16 VALVE TURBO
            6900 at 70???? Maybe 3900 rpm. When you take the cover off you will see for sure what is in there.
              I legitimately laughed aloud thinking of hitting 70mph at 7.3k in 5th.
              That's almost second gear sizing.
              Beater=/= Sleeper
                hahahaha!!!! OMG, I cant believed I typed that! Sorry, meant 2900-3200 rpm. :D :lol:
                Mazda
                1988 Black 323 GT
                DOHC 16 VALVE TURBO
                  Anyone else wanting the 1:717 5th gear.... the capri is a pretty common one u can pull the cover on the car and swap the gears pretty easy...and saves about 500 rpm from the stock mazda 323 gtx gears (if i remember correctly)
                    Monster those two trannies have the same 5th gear set.
