94 1.6L 4WD in NZ
    Epic, the leaves in the heater fan.
      Made a heck of a noise.
      Still having a lot of trouble finding any(altho I need 2) of these 29mm bushes. Damm this rareness car.
        what exactly is that?
          It isssssss, the part that attaches to the transmition, as shown in this diagram here that I picked up from the Mazda dealership.....no part number thow......
          so I may end up taking it to a friendly machine shop in town.
            Yeah so big reveal:
            Car is 94,not 95 like rego says(but that's fine)
            Googled bah6r, it came back with e-bah6r and it says it's packing a b6de...... Bummer!!!!
            I thought it had a b6ze(Rs) ..... So how can I tell? (Thanks wikipedia)
              I if I search the name on my ecu there I get nothing....odd.....
              This auto get your attention
              What a ya think? Bwahaha
                what turbo is that?
                compressor wheel specs? turbine wheel specs??
                b6dg... yup never heard of it
                  It is one of a rx7 twin turbo setup, so spec are sketchy, but flanges would be easy to get. I don't think anyone has a map for it thow. Was a trade me buy for like 25 bucks( both turbos and header)
                  So yeah, rx7 turbo, on a b6de, yeah, or na?
                  Gawdammit, has anyone? Gawdamm rear car......
                    YA!!! feed it much boost!
                      Wouldn't that be something!!!
                      However nothing will happen, and indeed nothing has happened, for a while because I'm going on holiday, well I'm already on holiday, but tonight me n my girlfriend head to Hungary, via 19 hours stop over in Singapore.
                        Home and with bad news
                        Warrant of fitness man didn't like my fog lights, said they were more like driving light pattern, so I Esther have to rewire them or remove them. I removed them.worse still, he said my headlights almost failed due to the detearation of the lenses.....
                        Is it worth trying to open them up to polish the inside?
                        I'm doing a lot of thinking into mega squirting this thing via piggyback.
                          put in one of those evo8 ecu setups. **** MS.
                            Went to the dealer, they couldn't give me an Ecu diagram.
                            Can anyone help with a pin out or experience in b6 ecus?
                            Thanks
                              Look up Evo 8/9 6spd shifter bushings, they should fit your shift cables.
                              I got some aluminum ones off eBay and installed them in my 1990 4wd JDM familia.
                              You might even find bronze oilite ones if your lucky, they are better than the aluminum ones
                                I looked into the evo bushings and as far as I could find, I would have to buy two sets, as I need two of the bigger bushing only.
                                I have used silicon to fill and glue, I think it has made a difference.
                                Appreciate your input though thanks.
