93 lx
    Drives completely different! (Besides the fact that it now drives straight and doesn't rock)
    Sent from my m8wl using Tapatalk
    ClubProtege
      Needs moar LOW!
      New rims/tires always makes a ride completely different. Its great that is goes straight too haha.
        I love driving my Protege. No one gets it. But I love it.
        I pulled in the driveway, popped the hood just because I like to look at it and my coolant tee was busted and spewing coolant. I replaced it with another crappy tee. Definitely need to find something better quality.
        Now to decide where I want to put my stickers!!!!
        ClubProtege
          what coolant T????
            Originally posted by FE3-323 View Post
            what coolant T????
            I teed into a coolant line for the turbo.
            I'd like to know if there's a better way to do it.
            ClubProtege
              ClubProtege
                Are you not using the coolant feed on the block?
                DX BP swap/turbo build
                  Yes. Coolant feed from the block, return is to a tee
                  ClubProtege
                    I see. I have a bypass pipe from a DX if you are interested. Has a nipple like the gtx but it points straight up. Used it on my last build. I have a gtx one for this go around. lmk.
                      [emoji2]
                      ClubProtege
                        now what in thee world
                          Packages from the Polish Connection. Looks like headlights.
                            *ding ding ding*
                            ClubProtege
                              I had a bit of free time to play around. Figured out fairly easily that my throw out bearing has gone bad. It sounds nasty when I push the clutch in.
                              My house still isn't done, so I don't have the time or place to change my clutch, weld my diff pin, lighten my flywheel, out replace my throw out bearing. I guess she's gonna sit for a while :*(
                              I played around and disconnected the relief side of my supra bypass valve. I learned that it's leaking a bit. It sounded cool though venting to atmosphere
                              ClubProtege
                                im surprised to hear the BOV is leaking.
