93 lx
    Originally posted by FE3-323 View Post
    hoping the disty is the solution
    Hmmm... Have to rotate distributor forward for it to crank now. Before, I was rotating it to the back to get it to crank. I'm checking the timing now.
    [emoji30]
    Sent from my m8wl using Tapatalk
    ClubProtege
      Hmmmmm.... I wish I wasn't such a noob.
      Ok. When I jump ten+gnd, I have to rev it up and slowly let off the gas (very slowly) to get it to even idle (idles at about 250rpm). I adjusted the idle screw so it idles up at 750rpm. I set the base timing (with ten +gnd jumped). I pulled the jumper and the car started (probably helps that the engine is warm). It idles at 750rpm (even after having adjusted the idle screw in diag... I don't understand that, but whatever).
      The timing mark was very consistent (was very very jumpy before the new distributor).
      I gotta wait until tomorrow to test drive it. The wifey is getting a little frustrated [emoji5]
      ClubProtege
        the engine was not synchronized:D
        Enviado desde mi GT-S5830M usando Tapatalk 2
          like this to fullthrottle
            It still won't crank when cold.
            ClubProtege
              That sounds like IAC valve has problem
                Maybe iac valve has problem
                  of which ECU changed when cables were you moved from place
                    Help.
                    6 minute video of me and the Protege doing crap.
                    ClubProtege
                      Wires which were you exchange in ecu
                        I swapped 2L and 2M
                        ClubProtege
                          uff is a broken head and guru of the forum are
                            Timing mark location it ok
                              What about your Fuel Pressure Regulator? Had that tested yet?
                              Not What you build, But HOW.
                                I carefully watched the video and showed it to a friend and you have time engine checker
